Kind of an off-the-wall question ... I've been searching extensively to see if this has been asked, but no luck so far.
Car/boat/motorcycle amplifiers are all listed as 12V input, sometimes listed as a range ... for example, 9V to 15V. What happens if you hook such an amplifier up to an input voltage below its minimum? For instance, 6 volts. Would the amplifier put out a fraction of its rated power? Would it simply refuse to power up? Or would it do something else entirely? |
#2 |
Most likely won't do anything, or if it does produce any sound at all, it will probably be very distorted.
Mike |
#3 |
Well that's disappointing ... thanks for satisfying my curiosity though.
#4 |
For chip amps, they may do any of the above.
For amps with switching power supplies, 6v is too far below the design voltage (12v). Most amps would refuse to power up. The power supply driver ICs in most amps require more than 6v to operate. If the power supply driver IC doesn't function, the amp won't function. This applies to amps with switching power supplies that use a driver IC (virtually every amp that produces more than 20w RMS into 4 ohms).
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Amplifier with 220 input voltage, will it work in US? | usmcjlp | Solid State | 5 | 15th April 2010 06:19 AM |
| Amplifier main capacitor replacement - voltage question | Tino | Pass Labs | 22 | 12th November 2008 04:27 PM |
| Kicker SX650.1 Input Voltage Question | Flyin11 | Car Audio | 3 | 20th May 2008 12:24 AM |
| Input voltage | lpd | Tubes / Valves | 2 | 11th July 2006 05:49 PM |
| Input voltage | seahag | Chip Amps | 4 | 30th November 2004 03:34 PM |
| Page generated in 0.06157 seconds (76.71% PHP - 23.29% MySQL) with 10 queries |
