Hello
I search simple schematic of power supply to use with class T amplifier. I need supply from 12vdc to 22Vdc-31Vdc with current of 10A in continuous. My project is to build a power amplifier for my car. The supply must have a remote control and i haven't find a schematic of power who have this ![]() Do you think i can modify a push-pull supply from car audio to only have one dc output ? If you have an idea to build it, please help me ![]() Thanks |
#2 |
i use this site when im building something.
Electronic Circuits - Free Electronic Circuits |
#3 |
Nice website
![]() thanks timwebb |
#4 |
You can use the same type of power supply that you've built in the past. Wind the transformer to a 1:1 ratio or just a bit higher (1-2 added turns to the secondary for an unregulated power supply). Leave the secondary center tap unconnected (or don't have a secondary center tap). Use the output of the negative rectifiers as the ground input to the T amp. Use the output of the positive rectifier as the positive rail for the T amp.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
Hello Perry
Thanks, so i adjust the number of turn of wind at the secondary of the transformer and removed 3 turns to have 28.8Vdc at ouptut. But now when i use the amplifier and measure the voltage at the ouput of the supply, i have 16.8vdc ![]() It's really strange because when i use the supply in pushpull mode, the voltage don't change with amplifier connected at ouput. have you an idea of the problem please ? Thank in advance
#6 |
Hello
I resolve the problem with new transformer ![]() now i have the good voltage "21vdc" at output with the amp connected ![]() Now i will test the class T amp in my car
#7 |
| Would this work? (15VAC to 12VDC & 24VDC) | diyguitarmods | Power Supplies | 16 | 6th May 2011 09:04 AM |
| Anyone tried this 12vdc 1A supply? | dublin78 | Power Supplies | 1 | 11th June 2009 04:27 PM |
| Simple BIG 12VDC supply ideas wanted | MadMutt | Power Supplies | 29 | 23rd October 2007 11:47 AM |
| convert a 12VDC, 800ma wall wart to 22-24VDC, ~400ma | Anthrax | Power Supplies | 3 | 9th May 2005 05:44 AM |
| Page generated in 0.08287 seconds (79.39% PHP - 20.61% MySQL) with 10 queries |
