I have an Old Black Orion 280GX with a mono circuit (ala Perry Babin) used to run one midbass. Recently the speaker started making a sound like I had blown it. I switched speaker wires and the other speaker made the same sound, so it has to be the amp. The amp is under my front seat and is real tough to pull out because of the way I have it wired up.
When I turn up the gain it is anything but linear and I know that the old Orion’s have issues with the gain POTs. Anyway, waiting for suggestions. I will get things started. 1-Don't be a baby, pull the amp. |
#2 |
Try connecting the signal via the RCA jacks and connect a speaker to one channel at a time to see if if one channel is defective.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
i can not do that without taking the amp out of the car because the amp only has two speaker wires coming out of it because I thought I would always use this amp in mono. I will take the amp out this week and do that test.
#4 |
If it has the small black wire coming out of it with the main power/ground wires, you can use that as a neutral speaker wire (negative for the test speaker) and use either of the ones coming out of the plug as the positive for the test speaker.
#5 |
I tested the amp in stereo mode with the same 80Hz test tone into both channels and found that one channel looked clean while the other had an odd waveform, see picture. Increasing/Decreasing the gain did not seem to have a large affect on the waveform.
A secondary issue I found with the amp was the RCA connector on the other channel. When the cord was wiggled the signal seemed to go in and out. I switched cables to verify it was not the external cord itself. When looking inside at the RCA connector and surrounding components I did not see any bad solder joints. |
#6 |
Which channel (yellow or orange) was distorted?
#7 |
The amp is at work and I am at home, but I will be at work tomorrow. Can you tell me what to do if it is the orange or yellow wire?
#8 |
I need to know which one to tell you what to check next.
#9 |
I believe it was the right side.
#10 |
Wait until you're sure and give me the color of the speaker wire for the channel.
| Improving Orion 280GX for bass & Sub | mitchyz250f | Car Audio | 17 | 20th March 2011 08:41 PM |
| Orion #5 | Clipped | Car Audio | 1 | 21st November 2008 04:34 AM |
| Orion 280GX amp repair | thegmann | Car Audio | 11 | 11th April 2008 05:44 PM |
| Orion NT 200 vs Orion 2150 SX | Clipped | Car Audio | 3 | 12th June 2007 01:55 PM |
| Orion 280GX | redblaze | Car Audio | 35 | 19th September 2006 05:06 PM |
| Page generated in 0.08739 seconds (77.30% PHP - 22.70% MySQL) with 12 queries |
