Go Back   Home > Forums > General Interest > Car Audio
Old 19th August 2011, 01:02 PM   #1
Default ks-ax302 JVC
Got this amp for repair. sound from outputs - high frequencies sounds disorted, when all filters are off. When comes bigger bass - amp is shutting down, green light turns off. What should look for? Power and output transistors seems to be okey. But seems like this amp was repaired before. KTD998 has replaced with this, i guess, 2sd998. Why there is such a difference with size? Is it ok to leave it and dont replace? I have service manual.
DMM
Old 19th August 2011, 06:04 PM   #2
Not all 2Sx... convert to KTx... These are entirely different transistors (inside and out).
Are you saying that the large transistor was replaced by the smaller transistor in a previous repair? If so, that won't work. Not even the pin configuration is the same.
Old 19th August 2011, 06:09 PM   #3
Only one transistor was replaced with this 2sd.
DMM
Old 19th August 2011, 06:15 PM   #4
Email me the service manual.
babin_perry@yahoo.com
Which transistor was replaced with the smaller one?
Old 19th August 2011, 06:45 PM   #5
Perry, I was looking at datasheet and I didnt found difference
KTD998 KTD998 pdf, KTD998 description, KTD998 datasheets, KTD998 view ::: ALLDATASHEET :::
2SD998 http://www.svntc.com/TPDF/1698.pdf
manual sent, i will take a look which one was replaced.only one KTD998 was replaced with 2SD99. I should check the other channel output sound.
DMM
Old 19th August 2011, 09:41 PM   #6
The datasheets you have are both for the larger transistor. The smaller transistor is obsolete so it's difficult to find the datasheet for it. You will have to get the larger KTD998 or an equivalent transistor.
From the service manual, it appears that the transistors are clamped down by a plate. If that's the case, you should be able to use the FJA4313 and FJA4213 as subs (to replace both outputs in the defective channel).
Also check the emitter resistors to confirm that they're within tolerance.
Old 20th August 2011, 07:29 PM   #7
Well, You suggest to replace KTB778 with FJA4213 and KTD998 with FJA4313? If so, then i will order. I looked at datasheets and I was thinking, that they will not work as substitutes.
DMM
Old 20th August 2011, 07:32 PM   #8
What makes you think they're not good subs?
If yours have an insulated back on them, you will need to add insulators between the transistor and the heatsink for the FJA parts.
Grundig Console KS 526 elbinster Solid State 0 17th August 2011 09:43 PM
need color pinout for jvc ks-es200 eq havieri23 Car Audio 0 27th April 2008 05:41 PM
FS: CS4390-ks A'af Swap Meet 0 31st March 2008 09:07 AM
Greetings from KS ricochet Introductions 2 16th October 2005 03:40 PM
JVC KS R390 Digital Synthesizer Tuner cblizard Everything Else 0 23rd September 2003 03:14 PM
Page generated in 0.11689 seconds (70.06% PHP - 29.94% MySQL) with 10 queries
