Im working on an amp that has the green bodied inductors..
The color bands are black,purple,yellow..
I believe the are 47 MH (micro Henery)
Wondering can i replace theese with a 47 micro farad 100 volt disk cap or not?
Reason im asking is because theese have been messed with and the legs are almost broken off
Ok thanks..
Next question is This amp is my friends and he wants me to see if i can get it working again...
Amp powers up and relays engauge but no output at all...
Do i need to start a new thread and list some voltages on the output driverboard pins and rail voltages ect??
You're looking at the wrong voltages on the datasheets. The number in the part number (i.e. 350) is the average breakdown voltage and it's only guaranteed not to breakdown at about 300v.
Why not refer servicing to someone like dB-R?
If you have made up your mind to repair it, order the right parts. If you install the wrong ones and there is a problem, you may waste a lot of time troubleshooting.
