Go Back   Home > Forums > General Interest > Car Audio
Old 17th August 2011, 02:58 AM   #1
Default power acoustik LFA1 4000d
hi am working on a power acoustik LFA1 4000d amp c176 is missing anyone no the value of that cap?
Old 17th August 2011, 03:07 AM   #2
If no one can help, post a photo of the inside of the amp and I'll see if I have information on a similar amp.
Old 17th August 2011, 01:00 PM   #3
LFA1 4000d
Old 17th August 2011, 05:18 PM   #4
The OVN1-4000 seems to be very similar. On the OVN1-4000 and the OVN1-5500, there is no component installed in that location.
Old 17th August 2011, 05:36 PM   #5
Well this amp came in with a burn PS fet and gate resistor.I will replace them and test for audio,maybe that cap is should not be in that model also.Thanks for the quick reply
Old 17th August 2011, 06:31 PM   #6
The OVN1 amps have a serious design flaw that causes the legs of the FETs to break. If any of the legs were weak, they're likely to break soon. You need to install a support on the top and bottom of the board to sandwich it between the heatsink and the bottom cover to prevent the board from flexing.
Old 19th August 2011, 09:02 PM   #7
You are correct 4 fets had broken legs and started arking when i power it up.After resoldering them the amp power up fine and is playing good audion.I think i will use some silcone to keep the board in place. Thanks
Old 19th August 2011, 09:46 PM   #8
You need to use something to support the board in the middle and that's not going to be difficult to remove if you have to disassemble the amp later.
Power Acoustik G540-2 mike49504 Car Audio 1 26th April 2011 02:34 AM
Power Acoustik LT1440/2 spooney Car Audio 3 26th March 2011 07:41 PM
Power Acoustik TS980 sparks, blows fuses even without power on. BoeroBoy Car Audio 7 30th September 2010 02:17 PM
Power Akustic LFA1-5500D Simbalage21 Car Audio 4 29th April 2010 10:39 PM
Help me to fix POWER ACOUSTIK please! Mordor Car Audio 10 13th February 2006 07:58 AM
Page generated in 0.08984 seconds (77.35% PHP - 22.65% MySQL) with 11 queries
