#11 |
If I'm reading it right ~10 ohms
#12 |
Does it blow the fuse without remote voltage applied?
Are you sure that you don't have the positive and negative connections reversed on the power connector?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#13 |
Power is not reversed. And it blows fuses without any speaker, remote voltage, or RCA's attached.
#14 |
What size fuse was it blowing?
#15 |
It acts as if it has a a low resistance load. Its not a 0 ohm short. When I plug it in the interior lights of the vehicle dim and then the fuses pop. The whole thing takes 2 to 3 seconds to happen.
#16 |
20 amp
#17 |
Confirm that you have ~10 ohms from the gate legs of the power supply transistors in each bank to the first leg of one of the MPSA56s.
If that's OK, you need to check the two MPSA56s. You need to confirm that neither is leaking and that each transistor has two intact junctions. You should remove them from the circuit for this test.
#18 |
I have ~10 ohms from the gate legs to the first leg of the A56's. How do I make sure that each transistor is intact and not leaking after they are removed?
#19 |
Remove the two A56s from the circuit (do NOT apply power with them out of the circuit).
Go to the basic transistor testing page (link in sig line below) and find (and read) the parts highlighted in the attached image. Fill in ALL text fields on the applet and post a screen cap of the applet (instructions provided in the applet).
#20 |
I attempted to upload the screen shots for the two transistors but encountered an error stating it didn't have a security token. But I can give you the measurments, they are basically the same for both. Only Measurments 1 and 6 on both transistors actually have measurments. Transistor 1 read 3.75M ohm and .638 on diode, and measurment 6 read 3.63M ohms and .635 on diode. All other measurments read OL. On transistor 2, measurment 1 read 3.72M ohms and .631 on diode. Measurment 6 reads 3.53 M ohms and .627 on diode. All other measurments read OL. I hope this makes sense.
| Orion HCCA 250r diagram of BJT's, FETs, and rectifiers | ash4kel | Car Audio | 1 | 6th August 2011 08:11 PM |
| Orion hcca 250r and 225r grounding out | ash4kel | Car Audio | 3 | 31st March 2011 02:44 AM |
| kicker zr1000, orion hcca 250r, mmats d800.2, mtx6500d, mtx 942, rockford punch 45 | ernie cosillos | Swap Meet | 2 | 16th February 2011 05:56 PM |
| Orion hcca 250r | mike49504 | Car Audio | 4 | 4th November 2010 07:18 PM |
| orion hcca 250r schematics | ernie cosillos | Car Audio | 20 | 21st October 2010 05:44 PM |
