diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Audiopipe AP10001D (http://www.diyaudio.com/forums/car-audio/194395-audiopipe-ap10001d.html)
mike49504 10th August 2011 11:12 PM
Audiopipe AP10001D
Outputs check good in this amp..
When i power it up and place black meter probe on output - terminal and
red probe on + output terminal i get - 2.62 volts ..
They guy said if he hooks up a sub to it it makes the sub flutter ..
Any ideas??
Perry Babin 10th August 2011 11:52 PM
Does it make a speaker flutter on the bench?
If so, does it act differently with the RCAs connected/disconnected?
mike49504 11th August 2011 01:38 AM
it pushes the cone of the speaker outward with and without rcas plugged in
I cant get it to flutter but i can tell theres DC present by hooking a test speaker up.
Perry Babin 11th August 2011 02:11 AM
Is there DC on the RCA shields?
Place the black meter probe on the amplifier's ground terminal.
mike49504 11th August 2011 02:20 AM
No voltage at all on the rca shields
Perry Babin 11th August 2011 02:36 AM
Is there DC on the output pins of any of the op-amps?
mike49504 11th August 2011 02:43 AM
U3 TLO74C Pin 16 has 2.37 volts on it ...
All other op-amps test fine
Perry Babin 11th August 2011 02:45 AM
What's the DC voltage on pins 12 and 13?
P.S. only 14 pins.
mike49504 11th August 2011 02:47 AM
Sorry meant pin 14..
Pin 12:0
Pin 13:0
Perry Babin 11th August 2011 02:49 AM
More resolution is needed. Post the actual meter reading (3 decimal places).
Resources saved on this page: MySQL 18.75%
