#11 |
Pin 12:0.00
Pin 13:0.00 Pin 14:2.36 Pin 6:-0.06 |
#12 |
There's nothing definitive there to say whether it's defective or not.
Can you post a photo of the inside of the amp?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#13 |
Yes gonna go take a pic right now..
#14 |
Let me know if u need more
#15 |
I try not to suggest replacing parts without a good reason but without a schematic diagram or more information about the circuit, I think replacing that op-amp may be the easiest thing to do.
#16 |
I replaced the op-amp still get 2.43 volts on Pin 16..
If i remove the outputs i get 0.24 volts on pin 16.. |
#17 |
See if you can get a schematic diagram for the amp.
#18 |
Still waiting on Audiopipe for a schematic..
When amp is powerd up If i place the black meter probe on amps ground terminal And red probe on 1 lead of output filter inductor I get -1.69 volts... Is the normal or is there a problem there?? |
#19 |
It's not normal to have more than 1.5v of DC across the speaker terminals of any amp. That's the way you should measure for offset.
| Audiopipe AP-15001D | mike49504 | Car Audio | 8 | 29th July 2011 08:55 PM |
| 1500 audiopipe | timwebb | Car Audio | 2 | 5th April 2011 11:44 PM |
| Audiopipe AP15001D . In need of an inductor | spooney | Car Audio | 14 | 24th January 2011 11:05 PM |
