Go Back   Home > Forums > General Interest > Car Audio
Old 10th August 2011, 02:12 PM   #1
Default Anyone have any experience with a memphis MCH1300 5 channel amplifier
I have a memphis model: 16-MCH1300 75wx4 class AB/1100wx1 class D amplifier I was wanting to know if anyone has any schematics for this amp because all of the resistors by the output transistors are burnt and I dont know what resistors to replace them with.
Old 10th August 2011, 03:07 PM   #2
Are you possibly referring to the power supply FETs?
They use 22 ohm resistors.
Old 10th August 2011, 05:12 PM   #3
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
I beleive the output transistors for the Class-AB section are stamped IRF540/IRF9540 and there are 4 of each in this section of the amp. I forget what the Class-D section uses but probably similar and in higher quantities on both sides of the heat sync. The power fupply fets are close to the ~6x 20A fuses on the board and are maybe IRF3205.
Edit: I just looked up my old post, and it seems that is if this amp is similar to the Memphis Belle I worked on previously, then it may be using two types of PS fets: IRF3205 and FQP50n06. Check my post here:
Memphis Belle ST-1300D
Old 12th August 2011, 05:15 AM   #4
Do you guys think it is possible for me to fix this amp by just replacing all the transistors and all the burnt resistors with new ones or is there allways something else that had to go wrong for it to short the transistors and burn the resistors ? When you put power to the amp the green light comes on and doesn't go into protect mode but no sound comes out of the speakers. When you look inside the amp you can clearly see the row of burnt resistors and transistors I can post pictures if that would help any.
FS/memphis belle mb-17 6-channel 1200 watt at 2-ohm beast ncamps Swap Meet 0 14th April 2009 01:01 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Yet another N-Channel Amplifier Pelle Solid State 50 10th January 2005 07:48 AM
6-channel Amplifier halvardf Solid State 7 3rd July 2002 02:15 AM
Page generated in 0.07686 seconds (77.49% PHP - 22.51% MySQL) with 10 queries
