Go Back   Home > Forums > General Interest > Car Audio
Old 10th August 2011, 02:09 AM   #1
Default car stereo connected to 32 ohm driver?
What would happen if I connect a 32 ohm headphone driver to a car stereo receiver rated for 2 to 4 ohms with 40w output? If it will detonate the rec can someone tell me what components are needed to stop the ensuing smoke cloud? Thanks.
Old 10th August 2011, 02:21 AM   #2
theAnonymous1's Avatar
Ever watch the 1987 film "The Gate"? Gateway to hell is all I'm sayin'.
Actually, worst case is you fry your little driver with ~2W of power.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 10th August 2011, 05:58 AM   #3
sofaspud's Avatar
What are you attempting to accomplish? Are you trying to add a headphone output to your head unit?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 11th August 2011, 02:59 AM   #4
OK, I know that headphone drivers use just millwatts of power, so 2w would melt things, but wouldn't the resistance of the drivers drop the wattage? It has been a long time since I studied the PIE triangle. And yes, Sofaspud, I am attempting to run headphones with a car (boat) stereo, on my motorcycle in the helmet to be exact. I posted the same question earlier, but got no useable response, so I tried again using fewer words. I am not using the 3 pole 3.5mm plug and jack, I found a source for a 4 pole 3.5mm plug and jack, so combining grounds isn't an issue any more. The output of the head unit is 40 watts for 2 to 4 ohms, the resistance of the drivers is 32 ohms. Thanks is advance for the help.
Old 11th August 2011, 03:38 AM   #5
infinia is offline infinia  United States
infinia's Avatar
use an L pad to knock levels down to about 20dB or so, try 110 ohms series followed by10 ohm parallel wired across the headphone socket.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 11th August 2011, 04:40 AM   #6
Originally Posted by scwten13 View Post
.... but wouldn't the resistance of the drivers drop the wattage?
Yes, down to around <2W with a 32-Ohm load.
2W is still way too much, so you need to make a voltage divider like infinia suggested.
Old 11th August 2011, 12:28 PM   #7
You should know that people won't look out for motorcycles. You need to be as aware as possible of your surroundings and having headphones (or audio in your helmet) will block out sounds that you really need to hear.
Old 17th August 2011, 01:45 AM   #8
ppia600 is offline ppia600  United States
You could also use a dual isolation transformer wound to get the ideal drop and prevent headphone obliteration.
Don't worry... you can always turn the gain down!
Old 18th August 2011, 02:42 AM   #9
And how would I come across a dual isoaltion transformer?
Old 18th August 2011, 08:18 AM   #10
dumb question, but the reciever doesn't have rca out? and, what is the purpose of the driver? how much power does it drive to the headphones?
My sub doesn't play when connected to the stereo. pikipupiba Car Audio 8 10th August 2011 04:39 AM
amplifier works connected to PC .. but not when connected to car radio anwaypasible Analog Line Level 1 2nd March 2011 07:42 PM
Ohmite 32 ohm 300W rheostat power resistor boywonder Swap Meet 0 31st May 2009 01:37 AM
How to setup using Extremis 4 ohm driver in 2-way configuration for car audio kippo Multi-Way 1 6th August 2008 11:07 AM
32 ohm bass amp. Tweeker Tubes / Valves 5 9th March 2006 12:43 AM
Page generated in 0.09252 seconds (77.23% PHP - 22.77% MySQL) with 10 queries
