Hi
I`m working on a stetsom 14k5. so far I have replaced 5 output mosfet, and the 5 gate resistors. the amp powers up and has audio, but there`s -20 volts at the output. any sugestion? Thanks in advance.
fluke 50 mhz scope,35 amp power supply,0.5-12v adj power supply, fluke 179,hot air desolder gun, merit multyfuntion signal tracer/generator. |
#2 |
HI:
againg having problems with this unit, after replacing one of the driver board with an other use one, know I have -02 volts for about 3 seconds, then it goes to -2.7 volts, at the speakers output. any suggestions?
#3 |
you've changed the 4011 check i, c u2 adjust the trimpot to off set
#4 |
Yes: I replaced the driver board, and ic 4011.
So I need to adjust the tripot?
#5 |
yes
| stetsom 1k5 h | megael9 | Car Audio | 8 | 26th July 2011 01:03 AM |
| stetsom | megael9 | Car Audio | 27 | 4th July 2011 11:40 PM |
| Page generated in 0.06175 seconds (78.63% PHP - 21.37% MySQL) with 10 queries |
