| Home | Forums | Rules | Articles | Store | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving |
Thread Tools | Search this Thread |
#31 |
diyAudio Member
Did you check U100-U107 for DC offset?
__________________
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#32 |
diyAudio Member
Yes I did and they had none but I will re-check today since I made an error in my last pin configuration when checking the others. Just to double check and confirm.
__________________
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#33 |
diyAudio Member
I had a similar issue with one of these amps. I somehow get the feeling people try to over-drive the input on these with bass boost, eq boost, full gain, and easy clipping. Something tells me the TL072 opamps cant take that much abuse, possibly due to regulated voltage levels or lack of protection on the opAmp inputs.
I even found one time that DC offset wasnt an issue, but the sound passing through was. If you throw a sine wave through the RCAs, you should be able to see the same wave of different amplitude on your scope; that is depending on the crossove and switch settings. In any case, if you have a sine wave on any of the opamp input pairs or outputs, then all 3 audio pins on that side of the opAmp should likely read something of the inputed sine wave. Again, I've found at least one case where a stuborn opamp had sound on input pins but nothing on output - not even DC, and the opamp was bad.
__________________
| Fluke 10 | Ramsey BS-601 | Topward 8102 | RS MiniAmp | Pyramid PS-15KX | DieHard |Big A$$ Resitor | Last edited by Dr Zeus; 16th January 2012 at 11:23 PM. |
#34 |
diyAudio Member
These amps have problems with DC offset in the op-amps because there are so many in series and any amplification boosts the offset from the previous stages.
The op-amp will only have signal on all 3 pins of one channel if the non-inverting input has signal driven into it. If the non-inverting input is grounded (and therefore has no signal) and the input is fed into the inverting input, there will only be signal on the output of the op-amp unless the op-amp is driven into clipping. Then you may see signal on the inverting input but it will likely be very distorted.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rockford fosgate 4.6 X | mike49504 | Car Audio | 14 | 28th May 2011 03:35 PM |
| Rockford Fosgate BD10001 | seankane | Car Audio | 61 | 21st May 2011 05:09 AM |
| Rockford Fosgate BD500 | seankane | Car Audio | 2 | 14th May 2011 10:31 PM |
| Rockford Fosgate | dtisme | Car Audio | 1 | 5th October 2010 11:39 PM |
| rockford fosgate p4004 | mike49504 | Car Audio | 17 | 28th January 2010 07:27 PM |
| New To Site? | Need Help? |
| Page generated in 0.07140 seconds (79.12% PHP - 20.88% MySQL) with 10 queries |
