Go Back   Home > Forums > >
Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Rockford Fosgate T30001
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 6th January 2012, 04:50 AM   #21
seankane is offline seankane  United States
diyAudio Member
seankane's Avatar
Good point I didnt catch that or it didnt sink in. I will check the regulators.
Thanks.
__________________
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 6th January 2012, 05:08 AM   #22
diyAudio Member
seankane's Avatar
Q29 power supply section regulator that is soldered to the board.........
There are only 2 legs on it......the in and out leg.........why is the middle leg missing? Isnt the middle leg the adjustable part of the regulator or the voltage reference?
Shouldnt the middle leg be on this regulator?
__________________
Old 6th January 2012, 05:35 AM   #23
diyAudio Member
seankane's Avatar
That leg is suppose to be missing I have figured that much out.
__________________
Old 6th January 2012, 05:51 AM   #24
diyAudio Member
seankane's Avatar
I am going to post readings of regulators including negative...........
Q14 LM337
pin1: -15.21
pin2: -26.99
pin3: -15.49
Q28 LM337
pin1: -4.69
pin2: -20.00
pin3: -5.96
Q13 LM317
pin1: 14.92
pin2: 16.22
pin3: 26.82
Q27 LM317
pin1: 4.83
pin2: 6.09
pin3: 16.85
Q5 LM317
pin1: 9.69
pin2: 10.95
pin3: 17.00
Q29 LM317
Pin1: 9.15
pin2: cut off and not used
pin3: 17.52
Q28 LM337 and Q27 LM317 are much lower than the rest any thoughts on that?
__________________
Old 6th January 2012, 06:19 AM   #25
diyAudio Member
seankane's Avatar
Perry read the results of my last post before this one.
I tested the regulators on a working T3001 and got the exact same readings as the unit being repaired. I dont think the regulators are an issue.
I checked the outputs on the scope on the working 3000 and the drains for 8 outputs have a square waveform and the other 8 the gates have a square waveform.
When testing the bad 3000 I can kinda of see the waveform but its pulsing very fast and hard to read.
Something is causing the output side of the board to pulse all of the signals all over the board, I think something from the power supply is perhaps sending a faulty signal to the output board and causing havoc but I am not for sure.
__________________
Old 6th January 2012, 02:13 PM   #26
Perry Babin is offline Perry Babin  United States
diyAudio Member
The LM317 has 6v out. That's correct. Is R68 open?
Old 6th January 2012, 08:48 PM   #27
diyAudio Member
seankane's Avatar
No it reads 0.000 ohms so I have to assume its ok.
What about the LM339 the U1 not the U5. It reads as follows......
Pin 1: 4.10
pin 2: 4.10
Pin 3: 16.0-17.0 fluctuating
pin 4: 4.35
pin 5: 4.98
pin 6: 4.98
pin 7: 8.20
pin 8: 4.33
pin 9: 2.750
pin10: 0.161
pin11: 1.630
pin12: 0.001
pin13: 5.0-7.0 bouncing all over the place
pin14: 0.075
pins 4-7 are inputs as well as pins 8-11.
3 being vcc and 12 being ground.
pins 4 and 5 feed pin 2 (1out)
pins 6 and 7 feed pin 1 (2out)
pins 10 and 11 feed pin 13 (4out)
Pins 8 and 9 feed pin 14 (3out)
Pin 14 has no output and I was wondering if the output from 14 supplied the 6 volts for the on delay?
I have been looking at the schematic closely and trying to determine if the right pins have the right voltage. I am not sure what some of the abbreviations mean though. As far as like P.S, S.D, and SD
For some reason when I test pin 11 for voltage the amp goes into protect and then the thermal light flashes on and off and the protect light is on but flickering.
I dont know if its relavent but thought it was kinda strange. What do you think?
__________________
Old 6th January 2012, 08:49 PM   #28
diyAudio Member
Let's stick with the 6v issue. Are you saying that on the good 3000 that there was no +6v on the op-amps?
Old 6th January 2012, 09:13 PM   #29
diyAudio Member
seankane's Avatar
Yes it did have +6v on the good amp.
I somehow got my pins mixed up on the amp we are testing. Probably late and very tired.
U304
pin1: -4.66
pin2: 0.072
pin3: -4.38
pin4: -5.96
pin5: 2.173
pin6: 0.275
pin7: 5.49
pin8: 6.09
U306
pin1: -4.37
pin2: -1.636
pin3: -1.678
pin4: -5.96
pin5: 0.001
pin6: -0.008
pin7: 4.37
pin8: 6.09
So I am getting the positive 6v on the pin 8 on both op-amps
I changed U304, U306, and U307 and the amp still is doing the exact same thing.
__________________
Old 7th January 2012, 03:51 AM   #30
diyAudio Member
seankane's Avatar
So now that I have cleared up my mistake and we have the +6v as we should (my appologies) what do you think of my findings on the LM339D (U1)?
__________________
Reply
Rockford Fosgate T30001Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate BD10001 seankane Car Audio 61 21st May 2011 05:09 AM
Rockford Fosgate BD500 seankane Car Audio 2 14th May 2011 10:31 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
rockford fosgate p4004 mike49504 Car Audio 17 28th January 2010 07:27 PM
New To Site? Need Help?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 15.79%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
