Rockford Fosgate T30001 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Home Forums Rules Articles diyAudio Store Gallery Wiki Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 6th January 2012, 03:03 AM   #11
diyAudio Member
seankane's Avatar
Quote:
Originally Posted by Perry Babin View Post
Post the voltage on all pins of U304 and pins 5, 6 and 7 of U306. Set the subsonic switch on. That should help prevent it from going into protect.
Pin 1: 2.171
Pin 2: 0.200
Pin 3: 5.45
Pin 4: 6.09
Pin 5: -4.59
Pin 6: 0.070
Pin 7: -4.35
Pin 8: -5.96
Pin 5: - 4.35
Pin 6: - 1.613
Pin 7: - 1.678
__________________
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 6th January 2012, 03:09 AM   #12
diyAudio Member
Pin 8 doesn't have +6v.
Old 6th January 2012, 03:14 AM   #13
diyAudio Member
seankane's Avatar
Not sure if you are telling me or asking me but I just double checked and my meter says -5.96 vdc 100% sure about this.
Is it suppose to be +6v?
If so does this mean the op-amp is defective or something else is causing this?
__________________
Old 6th January 2012, 03:19 AM   #14
diyAudio Member
It should have +6v on pin 8.
Do you need the schematic diagrams?
Old 6th January 2012, 03:24 AM   #15
diyAudio Member
seankane's Avatar
Yes I do.
Although I may still need your help.
It kinda reminds me of a BD1500 with the bad op-amp you helped me fix along time ago. I am not sure but the wierd stuff the amp is doing with the pulsing and chirping and popping noises through the speaker.
Wierd thing is it has noises coming from the power supply side and the output side. The internal frequency or chirping sound coming from the output side is transfered to the speaker when its hooked up.
So how could the output switch from positive to negative? Could the op-amp be defective in a way that could cause this?
__________________
Old 6th January 2012, 03:29 AM   #16
diyAudio Member
I think the positive regulator simply failed and without a positive supply, things were pulled down towards the -6v.
Check your email.
Old 6th January 2012, 03:31 AM   #17
diyAudio Member
seankane's Avatar
Thanks for the schematics I will change out U304 and see what I have.
__________________
Old 6th January 2012, 03:54 AM   #18
diyAudio Member
seankane's Avatar
I changed out U304 and still same result.
U306 also has the -5.96 on pin 8
I am not sure where to go next guess I will keep looking over the schematic.
__________________
Old 6th January 2012, 04:10 AM   #19
diyAudio Member
seankane's Avatar
What effect could R349 and R350 have if they are out of tolerance?
They dont check out good in the circuit, probably have to remove them to get a good test result.
__________________
Old 6th January 2012, 04:46 AM   #20
diyAudio Member
U304 isn't the +V regulator. Perry stated the regulator failed not the opamp.
Sent from my Punch 60.2
__________________
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Reply
Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate BD10001 seankane Car Audio 61 21st May 2011 05:09 AM
Rockford Fosgate BD500 seankane Car Audio 2 14th May 2011 10:31 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
rockford fosgate p4004 mike49504 Car Audio 17 28th January 2010 07:27 PM
New To Site? Need Help?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Copyright 1999-2017 diyAudio
Content Relevant URLs by vBSEO 3.3.2
Wiki
