Go Back   Home > Forums > General Interest > Car Audio
Old 9th August 2011, 12:50 AM   #1
Default Power Acoustic PA2-820
The left channel had 38 volts of dc on the outputs so i removed the outputs and replaced the drivers for the outputs..
Outputs are still out of the amp right now..
Problem im having is the drivers are getting red hot within 5 secs after power up..
Any ideas?
Old 9th August 2011, 12:40 PM   #2
Solder bridges, drivers orientated the wrong way, drivers in the wrong location...
Old 9th August 2011, 01:52 PM   #3
I checked there are no soler bridges,,,
And i took 1 driver out at a time and replaced it so im 100% sure that they are in the correct locations and facing the right way...
Old 9th August 2011, 02:13 PM   #4
There's nothing connected to the drivers, as far as I know, other than the supply voltage and a 220 ohm resistor connecting the two drivers. This would mean that all of the current would have to be flowing through the 220 ohm resistor. If the drivers were overheating, I'd expect the 220 ohm resistor to be overheating as well.
Is the 220 ohm resistor overheating?
Did you use exact replacements?
Were the drivers new?
Old 9th August 2011, 02:27 PM   #5
the 220 ohm resistor overheats as well..
I used the exact replacements..
Drivers were new
Old 9th August 2011, 03:25 PM   #6
Are the diodes connected to the bases of the drivers shorted?
Old 9th August 2011, 03:29 PM   #7
No i pulled them and checked both they test fine
Old 9th August 2011, 03:45 PM   #8
Does the bias transistor have an open junction?
Old 9th August 2011, 03:49 PM   #9
no
Old 9th August 2011, 06:13 PM   #10
You'll have to work your way back through the circuit, carefully checking the components until you find the fault.
Page generated in 0.08712 seconds (77.30% PHP - 22.70% MySQL) with 11 queries
