This amp is stuck in protection mode I checked all of the outputs and they test fine.. I pulled the rectifiers out and amp is still stuck in protection mode..
With the rectifiers in the amp heres what i get on the 494 Pin 1:0.97 Pin 2:5.00 Pin 3:4.76 Pin 4:0.18 Pin 5:1.50 Pin 6:3.44 Pin 7:0 Pin 8:13.44 Pin 9:0 Pin 10:0 Pin 11:13.46 Pin 12:13.18 Pin 13:5.00 Pin 14:5.00 Pin 15:5.00 Pin 16:11.71 Any ideas on where to start looking?? |
#2 |
Pin 16 is being driven high which is shutting down the IC. What's driving pin 16?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Theres a op-amp 4558 and a diode connected to pin 16
4558 Pin 1:12.36 Pin 2:5.00 Pin 3:13.18 Pin 4:0 Pin 5:6.09 Pin 6:11.56 Pin 7:0.59 Pin 8:13.19 |
#4 |
Pin 3 is being driven high which is driving the output of the 4558 high. What's driving pin 3?
#5 |
An A1266 transistor is driving pin 3
#6 |
Remove it, reinstall missing components and carefully power it up. Does it draw excessive current, have DC on the speaker outputs or does it produce clean audio?
#7 |
Once removed it powers up but draws excessive current
#8 |
Clamp all transistors, connect the current limiting resistor in series with the B+ line and measure the DC voltage across each of the emitter resistors. Which channel has significantly more DC voltage across the emitter resistors? Remember, all of the voltages will be well under 1v so measure as accurately as possible.
#9 |
Ok i found 1 emitter resistor with 6.22 volts across it
Which would be channel 1 |
#10 |
I have no information on that amp so I'm working in the dark.
If the transistor connected to that emitter resistor isn't shorted, check the driver for it. If it doesn't appear shorted, pull them to see if either is leaking.
| Digital Designs Z2 | mike49504 | Car Audio | 25 | 24th December 2010 05:51 PM |
| Digital Designs Z1 | mike49504 | Car Audio | 21 | 23rd October 2010 03:46 PM |
| Digital Designs Z2 | teen | Class D | 4 | 6th October 2010 06:59 AM |
| Digital preamp designs? | Helix | Digital Source | 11 | 13th September 2001 12:14 PM |
| Page generated in 0.09681 seconds (78.18% PHP - 21.82% MySQL) with 10 queries |
