Digital Designs A4
Digital Designs A4
Old 7th August 2011, 07:24 PM   #11
mike49504 is offline mike49504  United States
Ok it appears that someone worked on this amp before and have the outputs in the wrong spots ..
This amp uses C4467 and A1694's as outputs..
Does the A1694s control the positive or negative rail??
Old 7th August 2011, 07:27 PM   #12
Perry Babin is offline Perry Babin  United States
The C is generally on the positive rail but that's not always the case.
Find the terminal of the output transistor on the rail for the other channels and install the same transistors on the corresponding rail for each of the outputs in the defective channel.
Old 7th August 2011, 07:35 PM   #13
Ok it powers up green now and idle's perfectly.. Someone had every channel messed up..
Both C's were in 1 channel Both A's were in another and so on..
Old 7th August 2011, 07:43 PM   #14
OK now channel 2 has 22.87 volts of DC on the outputs.. I will check that channel to see what i can find out
Digital Designs A4Hide this!Advertise here!
Digital Designs Z2 mike49504 Car Audio 25 24th December 2010 05:51 PM
Digital Designs Z1 mike49504 Car Audio 21 23rd October 2010 03:46 PM
Digital Designs Z2 teen Class D 4 6th October 2010 06:59 AM
Digital preamp designs? Helix Digital Source 11 13th September 2001 12:14 PM
