I'm really getting frustrated trying to fix this amp.
The Power Supply is Good (4 pairs of IRFZ44 Mosfets with TL494, nothing special) The Amp is good (two pairs per channel 10A 100W Toshiba BJT) I had problems with "hum" the first time, and I changed out one of the inline-8 4558 opamps with a DIP-8 4558 opamp, and repaired two burned ground lines on the PCB and it worked fine. I get the amp back, same hum again. I later on got music by wiggling the PCB, but the music had a weird quality - I hooked it up BTL, but it played cancelled stereo (just the differences between the L and R channels) and this amp has no BTL switch. So I took it apart and resoldered all the solder joints in the amp on the input side, and now it hums still, now with no music. I changed out all the opamps to 4560s and it still hummed, just louder, LOL There's also another chip JRC 13600D that I can't find, and I don't know if this chip is good or not (I usually just change the chip when in doubt if I have one) I'm totally at the end with this amp, I look at it, the PCB looks simple, and yet I'm stumped on how to fix this thing. Any tips or ideas are greatly appreciated. Thanks, EWorkshop1708
You can call me Mad Professor, building crazy experiments in my Electronics Workshop Last edited by EWorkshop1708; 6th August 2011 at 08:21 PM. |
#2 |
With no RCAs connected to the amp, what's the resistance between the RCA shields and the non-bridging speaker terminals?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
I check, I get OPEN between those. Should it be short, or low ohms? It has two RCA in and outs. The ground (shield) is common on left and right in. Also common with L & R out, but it's open resistance from RCA shield from in and out, either L or R.
You can call me Mad Professor, building crazy experiments in my Electronics Workshop |
#4 |
In most of these amps, that should read 0 ohms. Look for an open ground trace between the RCA jacks and the secondary center-tap of the transformer. Sometimes it's a long thin trace in the center of the board that burns open.
#5 |
Thanks. The ground terminals on the rca jacks themselves were broken. You are the MAN Perry Babin.
| Difference between self oscillating and non-self oscillating D-amp. | sildex | Class D | 36 | 4th August 2010 03:30 PM |
| Self Oscillating (Oscillating Calculations) Help! | Reactance | Class D | 7 | 12th March 2010 07:37 PM |
| important advanced question. | lbstyling | Digital Source | 0 | 10th November 2009 10:37 PM |
| Most advanced cd-player? | Netlist | Digital Source | 2 | 29th August 2003 10:03 PM |
| More advanced marketplace | peranders | Swap Meet | 0 | 14th August 2002 08:03 AM |
| Page generated in 0.07890 seconds (73.98% PHP - 26.02% MySQL) with 10 queries |
