Go Back   Home > Forums > General Interest > Car Audio
Old 4th August 2011, 01:12 AM   #1
Default Hifonics Gen X Boltar
This amp powers up fine and idles perfectly for about 1- 2 mins and plays audio but with a buzzing sound heard through the speaker.. After the 1-2 mins the amp will draw excessive current and still play audio and the buzz goes away..
All ive done to the amp is replace the reverse polarity diode since it was defective..
Any ideas on where to start looking??
Old 4th August 2011, 05:38 AM   #2
Is the buzzing there without present without an input signal (RCAs connected?, no RCAs connected?)?
Old 4th August 2011, 06:16 AM   #3
Ok now i see why there is a buzzing sound..
On the Left channel with no RCA's plugged in I get 1.33 volts on the output terminals
On the Right channel I get -1.33 volts on the output terminals..
Old 4th August 2011, 06:20 AM   #4
How did you measure the voltage? Place the black meter probe on the secondary center tap or one of the non-bridging speaker terminals. Place the red meter probe on the bridging terminal of each channel. Do you read positive voltage on both channels?
Does the amp start to draw excessive current if left idling?
Were the transistors tightly clamped to the heatsink when the amp began drawing excessive current?
Old 4th August 2011, 06:21 AM   #5
Ok fixed the voltage problem on the channels i found a bad 2.7 ohm resistor that was out of tolarance... With no rca's plugged in i get no buzzing sound at all through the speakers.. only when rca's are plugged in
Old 4th August 2011, 06:25 AM   #6
yes the transistors were clammped to the heatsink.. It will only start drawing current after a min or 2 when everything in in the heatsink..
I let it idle out of the sink and it idles fine only had it powerd up for about a min due to the transistors for the swinger are getting hot..
Old 4th August 2011, 09:37 AM   #7
Swinger?
Were the bias transistors on the sink?
Did the current increase in both channels?
Defective insulators?
Old 4th August 2011, 11:04 AM   #8
Bad post!
Old 4th August 2011, 02:57 PM   #9
on the board it says swinger and there is a C2238 transistor in the location.
Dont know what it means but thats what it says on the circuit board..
Looking for a Hifonics VIII Boltar 807tubenut Car Audio 4 25th February 2011 02:03 PM
Hifonics Zeus Gen X Dr Zeus Car Audio 19 7th January 2011 02:25 AM
Boltar gen X op-amp. marko Car Audio 29 21st August 2010 04:13 PM
Sub for Gen VII HiFonics Morts Car Audio 0 26th May 2009 04:29 PM
Hifonics Boltar VIII Problem vypr Car Audio 22 19th February 2008 03:46 AM
Page generated in 0.12079 seconds (83.63% PHP - 16.37% MySQL) with 10 queries
