Rockford fosgate BD1500.1 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 3rd August 2011, 04:21 PM   #11
Ok if i disconnect the twisted wires nearest the power supply fets , I get 0 volts across the wires if i touch the board nearest to the power supply fets i get 149.8 volts
Old 3rd August 2011, 04:23 PM   #12
With the probes as previously suggested and the rectifiers in the circuit, do both read the same polarity or does one still have reversed polarity?
Old 3rd August 2011, 04:29 PM   #13
1 set has 156.0 volts
other set has 150.1 volts
They are both positive readings
Old 3rd August 2011, 04:30 PM   #14
Do you have the red wires in all of the +HV holes and all of the black wires in the -HV holes?
Old 3rd August 2011, 04:44 PM   #15
Ok so far all the wires are solderd back in the board and amp is idling perfectly.. So now im gonna solders the outputs back in and see what i come up with
Old 3rd August 2011, 05:10 PM   #16
Ok amp powers up and plays output but the current draw is still to high its about 8 amps of current draw at idle
Old 3rd August 2011, 06:00 PM   #17
Do you notice anything running hotter than normal?
Old 3rd August 2011, 10:03 PM   #18
NO
Old 3rd August 2011, 10:06 PM   #19
150v is a bit high. Is the voltage less now that you have everything back in the circuit?
rockford fosgate BD1500 stopped working NauTech Car Audio 293 2nd June 2015 01:19 AM
rockford fosgate bd1500.1 robbysankar Class D 6 2nd July 2011 09:28 PM
Rockford BD1500 seankane Car Audio 19 1st June 2011 01:40 PM
Rockford Fosgate BD1500.1 mike49504 Car Audio 4 17th March 2011 10:39 PM
Rockford fosgate Bd1500.1 mike49504 Car Audio 25 21st September 2010 05:24 PM
Copyright 1999-2017 diyAudio
