Go Back   Home > Forums > General Interest > Car Audio
Old 1st August 2011, 12:36 PM   #1
Default MTX JH 1200
Anyone have info on this amp??
I need to know the value of the following resistors
R62
R63
Old 1st August 2011, 06:42 PM   #2
Ok i figured out the value of R62 that is a 61. ohm resistor..
Anyone know the value of R63 it connects to the 3rd leg of all the power supply fets..?
And the gate resistors are 100 ohms..
Old 2nd August 2011, 09:30 AM   #3
If no one can answer your question, email MTX for the value.
Old 2nd August 2011, 01:10 PM   #4
I tryed that already and they said they had nothing on the amp since its still in production
Old 2nd August 2011, 01:13 PM   #5
Does the capacitor connect to a capacitor and the resistor/capacitor are connected across the source legs of each bank of FETs?
Old 2nd August 2011, 01:22 PM   #6
yes
Old 2nd August 2011, 01:28 PM   #7
Looking at other (older) MTX amps, it may have been a 10 ohm.
Old 2nd August 2011, 02:06 PM   #8
The more i look at it the more im thinking its a 61.9 ohm resistor..
There are a total of 12 power supply fets ( 75339P)..
For 6 of them there are 2 61.9 ohm resistors that connect to the source leg.
1 6.19 for 3 of them and 1 61.9 for the other 3..
Then i go over to the other 6 there is only 1 61.9 ohm surface mount for 3 of them and for the other 3 it must be a leaded resistor (61.9 ohms)
Does this sound right to you??
Old 2nd August 2011, 02:30 PM   #9
Are you referring to the resistor that I thought may be a 10 ohm resistor?
The gate resistors would not be in series with a capacitor and would not be connected to leg 3 of the FETs.
Post a photo of the area. I've never seen one of these so the circuit board designations aren't helping here.
If someone else has one of these, maybe they can help.
Old 2nd August 2011, 02:55 PM   #10
Yes refering to the resistor you thought was 10 ohms..
Help needed with Lectron JH 50 Amp astro_nut Tubes / Valves 4 14th November 2007 03:10 PM
Mayware / JH Labs tonearm problem Stanislav Analogue Source 12 12th January 2007 06:08 AM
Grace 707 & JH 4 tonearms for parts woody Swap Meet 2 19th December 2005 10:17 PM
lectron jh 60 help---------------- muccax Tubes / Valves 0 24th May 2005 08:20 PM
PASS-YAX2-JH pcb. jazzy Pass Labs 15 6th May 2003 08:24 PM
Copyright ©1999-2013 diyAudio
