I noticed one of the output filter inductors has the coating burned off on on about 2 turns of the windings.. Wondering whats the best way to recoat the windings or what i could use so they dont short?
#2 |
Each turn around the inductor is a bundle of multiple wires. Are only two individual wires burned or are two complete bundles burned?
Are the burned conductors on the terminal winding?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
1 bundle of wires burned .. It burned from where is solders to the board upwards and only burned like 3 turns is all.. Yes on the terminal winding
#4 |
You may be able to use heatshrink tubing to insulate the burned windings.
#5 |
Thanks for the info..
Next question is This amp has been worked on before by someone else and they did a horrible job So wondering id the IRF3205's are the orginal parts that belong in this amp?? |
#6 |
STP75NF75s were used in some of them. I've never seen 3205s as original parts but I can't say they were never used.
#7 |
Ok i remeber an amp that i had in at 1 point in time reading back through the threads.. The orginal part numbers were STP75NF75 with an 8 suffix..
I used 3205's to trouble shoot that amp and used the BD139's and 140's as replacements.. Then i stuck the STP75NF75's back in it after trouble shooting it.. Looks like someone replaced the orginals with 3205's in this amp And this amp has the orginal drivers still in it so i know its not the same one i worked on in the past... Wondering if the 3205's would work in this amp or is that the reason it may have failed?? |
#8 |
The 3205s should work.
The last character was likely an ampersand, not an 8.
#9 |
Ok thanks..
Last question I told this guy i will not warranty my work at all since he insist's running this amp at 1/2 ohm . I told him its not 1/2 ohm stable but he told me it will work since hes got a big battery bank and multiple runs or 1/0 guage power and ground.. He said he was running at a 2 ohm load but is switching woofers and hes gonna run it at 1/2 ohm.. Is there anything i can do to this amp to try and help it surrive the 1/2 ohm load or not really?? |
#10 |
Not really. Hopefully it will go into protect mode and not let him run it that way.
Before you repair it, tell him that you will show him that it works and that you will play it as long as needed to convince him that it's repaired but beyond that, there is absolutely no warranty. If he doesn't like that, reassemble it and give it back to him, broken.
| Hifonics BXI 2010 D | hirevlimit | Car Audio | 1 | 27th June 2011 12:25 AM |
| Hifonics BXI 1210D | mike49504 | Car Audio | 3 | 6th May 2011 02:17 AM |
| Hifonics BXI 2010 D | mike49504 | Car Audio | 90 | 10th January 2011 05:20 PM |
| Hifonics BXI 1606 | mike49504 | Car Audio | 4 | 1st October 2010 09:18 PM |
| Hifonics Bxi 1606d Please Help | dmeche | Class D | 3 | 25th July 2009 07:15 PM |
| Page generated in 0.09307 seconds (79.58% PHP - 20.42% MySQL) with 11 queries |
