Go Back   Home > Forums > General Interest > Car Audio
Old 31st July 2011, 05:01 PM   #1
Default output sub help
I have these two transistors B827 R and D1063 R.I want to no if they could work in place of D778 and B688.The rail voltage is 29v.
B827 R=http://www.nteinc.com/specs/2300to2399/pdf/nte2314.pdf
D1023 R= http://www.nteinc.com/specs/2300to2399/pdf/nte2304.pdf
D718= http://www.nteinc.com/specs/10to99/pdf/nte36.pdf
B688= http://www.nteinc.com/specs/10to99/pdf/nte36.pdf
Old 1st August 2011, 01:02 AM   #2
The NTE parts are not necessarily the exact equivalent. They're simply supposed to be suitable replacements. Therefore, the datasheets won't always match the parts that they replace.
The transistors you want to use are not suitable replacements. I'd recommend the FJA4213 and the FJA4313.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Page generated in 0.06501 seconds (70.10% PHP - 29.90% MySQL) with 11 queries
