Go Back   Home > Forums > General Interest > Car Audio
Old 29th July 2011, 02:12 AM   #1
Default MTX RT2200X
Got this in for repair and when you hook a speaker up to it, It makes a loud high pitched hum out of the outputs almost like a 2k sine wave... Any ideas??
Old 29th July 2011, 02:50 AM   #2
Broken shield ground on the RCA jacks.
Old 29th July 2011, 03:12 AM   #3
brokrn shirld ground through some components?? The leg that goes to the shield on the rca's themselfs is in tack
Old 29th July 2011, 03:40 AM   #4
Does it do it with no RCAs plugged in?
Is the shield ground intact in the signal source?
Old 29th July 2011, 03:48 AM   #5
I checked the signal source and the shields are good..
Yes amp does it with no rca's plugged in
Old 29th July 2011, 03:56 AM   #6
You need to see where the signal starts in the preamp section. It could be due to a broken pot, especially in the crossover.
Old 29th July 2011, 05:21 AM   #7
Replaced all pots and the crossover switch amp still does the same thing..
Old 29th July 2011, 05:35 AM   #8
Did you try tracing the signal before you tried replacing the pots and switches?
Old 29th July 2011, 05:43 AM   #9
Trace the high pitch from the output terminals backwards to the preamp section ?? Since the amp does it with no rca's connected
Old 29th July 2011, 06:47 AM   #10
Trace it from either end.
Help MTX TA3401 Cain Car Audio 9 3rd March 2011 02:43 AM
orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, ernie cosillos Swap Meet 3 12th February 2011 11:14 AM
mtx 300xd help mjrpainless Car Audio 8 4th January 2009 02:22 AM
Help me fix MTX 152 and MTX 500D hakentt Car Audio 94 8th December 2008 06:26 PM
MTX RT2200x changing smps output voltag xplod1236 Car Audio 10 10th May 2007 05:51 PM
Page generated in 0.08606 seconds (77.94% PHP - 22.06% MySQL) with 10 queries
