Go Back   Home > Forums > General Interest > Car Audio
Old 24th July 2011, 07:15 AM   #1
Default Directed D2400
This amp works if the switch is set to slave. It wont work if the switch is set to master Is this normal??
Old 24th July 2011, 07:32 AM   #2
Using the wrong RCAs as inputs?
Old 24th July 2011, 06:03 PM   #3
Im using the Correct RCA inputs..
Theres a Input and A line output ..
Im using the line input i triple checked that..
Old 24th July 2011, 08:29 PM   #4
Have you tried operating all pots and switches through their entire range with a speaker connected to confirm that audio never plays through?
If so, you will have to use your scope to follow the audio through the op-amps to see where the audio is lost.
Old 25th July 2011, 02:48 PM   #5
Ok fixed the switch problem
When i power the amp up the blue light on the top cover lights up for a sec then goes out.. Is this normal or is it suppose to be lit the whole time?
Old 26th July 2011, 03:25 AM   #6
I don't know about the light. I'd assume that it should always be on but I'm not sure. If no one here can tell you, look up the owner's manual to see if it mentions it.
Directed 1100 D mike49504 Car Audio 13 11th January 2011 05:26 PM
directed d2400 mike49504 Car Audio 17 24th August 2010 12:23 AM
Directed 1100 D mike49504 Car Audio 4 2nd August 2010 05:03 AM
Directed 750 D mike49504 Car Audio 35 23rd July 2010 04:51 AM
Directed D2400 mike49504 Car Audio 10 20th April 2010 04:52 AM
Page generated in 0.08084 seconds (77.75% PHP - 22.25% MySQL) with 10 queries
