PPI PC 21400
Left channel i got down to 0.08 volts on the outputs..
Right channel Wont drop any lower the 1.5 volts..
I added that 100 ohm resistor to the points marked in the photo is there a better way of fixing this problem so i dont have to cut into the driverboard?
Just asking because the guy will open this amp up and cry about the repair it it doesnt look factory
