Hello,
I am currently running a PPI5440, but recently it has started to play up. Occasionally whilst playing music, the amp just cuts out, initially i thought it was going into thermal cut out as I am running it into 2 ohm loads. But, when it last happened I shot round the back of the car expecting the LED to be showing red. But the amp had shut off, no LED lit at all. I checked that I had power at the +vs terminal of the amp and did, there was also 12v on the remote switching terminal and a very good ground. I gave the wires a wiggle with no change. About 5 mins later the thing just burst into life again (scaring the living daylights out of me). This happens quite often when I am listening to something. Is this a common fault on the PPI5440 or has anyone else had similar problems with one. Help Please Rees |
#2 |
When you checked the voltage on the terminals, did you have the black probe on the screw of the terminal block on the amp? If not, when it goes off again, recheck the voltage with the black probe directly on the ground terminal on the amp.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Hi Perry,
I did check the voltage from +ve to -ve terms on the amp, also checked the remote on to the amp -ve term. Going to pull the amp from the car a bit later and take a look inside. Rees |
#4 |
In a way it looks like i am losing the remote on signal inside the amp somewhere.
| PPI Promos 25 - Actual output? | Sub Ace | Car Audio | 12 | 19th January 2010 08:21 PM |
| Intermittent Output on Rotel | neddyboy | Chip Amps | 4 | 26th December 2009 10:55 PM |
| Help repair PPI 5440 | mandude | Car Audio | 0 | 4th October 2008 05:47 PM |
| ppi pc4100 no output, help! | rawadia | Car Audio | 27 | 17th March 2008 11:43 PM |
| Sanyo Mosfet intermittent maximum output spikes | litewate | Solid State | 3 | 3rd July 2004 11:43 PM |
| Page generated in 0.08545 seconds (75.27% PHP - 24.73% MySQL) with 10 queries |
