Go Back   Home > Forums > General Interest > Car Audio
Old 21st July 2011, 01:38 AM   #1
Default no sound out of subs from amp
i recently purchased a new amp for my car to power 2 subs. the amp i had before went bad(bestbuy tested it), so i already had all the wiring and subs, i just had to hook up the new amp. however, when i turn the stereo on i get power to my amp but no sound. i know the amp is fine because i tested it in another car. i used an output converter to connect the rca cables to my head unit. is it possible tht the output converter OR the rca cables just went bad? what else could be the issue? any help would be GREATLY appreciated.
Old 21st July 2011, 02:24 AM   #2
What make/model amp?
Old 22nd July 2011, 08:50 PM   #3
power acoustik OVN2-1800
Old 22nd July 2011, 10:07 PM   #4
Do you have a multimeter?
Old 22nd July 2011, 11:26 PM   #5
yes. to test the voltage? or ohms?
Old 22nd July 2011, 11:59 PM   #6
AC voltage.
Disconnect the RCAs from the amp, turn the head unit on and set the volume to about 3/4. Measure the AC voltage on the RCA jacks. Place one probe on the shield and the other probe on the center conductor. Do you see a varying voltage that increases/decreases with the volume level?
You can do this more easily with a steady test tone but it can be done with music.
Old 23rd July 2011, 12:29 AM   #7
nothing happened when i did this. what does tht mean? bad RCA cables and or ouput converter?
Old 23rd July 2011, 12:30 AM   #8
It could be either or an incorrect connection at the head unit.
Try it again directly on the output of the converter (not through the RCA cables).
Old 23rd July 2011, 01:36 AM   #9
still no signal
Old 23rd July 2011, 02:14 AM   #10
With the black probe on the case of the head unit, touch each of the speaker wires feeding the LOC. Do you see any AC on those wires?
ma audio hk-4000 ,no sound to subs ?MA AUDIO HK-4000,NO OUTPUT TO SUBS WRENCH030380 Class D 2 7th March 2011 11:38 PM
Dual 18" PA subs for live sound in club... hellonwheels PA Systems 30 22nd September 2010 09:04 PM
sound splinter subs Village Plank Subwoofers 3 11th April 2010 10:30 PM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
Want to build car amp to run a couple of 12" subs menaztricks Chip Amps 10 5th November 2005 04:39 PM
Page generated in 0.09895 seconds (77.14% PHP - 22.86% MySQL) with 10 queries
