Hi, i already searched and found some threads about that amp , but non were with the same problem that mine is. Since its a D-class amp, its a bit of an headache to me. When appling remote B+ and GND it wont do nothing, it wont draw any amps. I measured that the power reaches the board, i mean the connectors are correctly soldered to the board and thats not the case. What i noticed was that the TL494 dont have the correct values, for example, the 12V VCC is missing, so i soldered it out. Still no correct VCC on the solder pads or without the TL there mustnt be any correct values? Output transistors and the powersupply transistors seem to be okay. Has anyone the schematic or any ideas traceing down the link, that should give the 494 its neccesery voltage.
Sry for my bad english and thanks! |
#2 |
Post the DC voltage on all 16 pins of the 494.
IC# Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
IC#
Pin 1: 0 Pin 2: 1,38 Pin 3: 0 Pin 4: 0 Pin 5: 0 Pin 6: 0 Pin 7: 0 Pin 8: 2,32 Pin 9: 0 Pin 10: 0 Pin 11: 2,32 Pin 12: 2,32 Pin 13: 0 Pin 14: 0 Pin 15: 0 Pin 16:0 THIS IS MEASURED IC OUT! Last edited by mekaiver; 20th July 2011 at 11:51 AM. Reason: typo |
#4 |
#5 |
Q17 seems to be okay but cant locate Q18. Is it on the modu1 board under that black epoxy?
| sinus live sla-1500 repair need help | Ground Zero | Car Audio | 44 | 16th January 2012 04:06 PM |
| Technics SL-1500 schematic anyone? | audiomatic | Analogue Source | 31 | 4th January 2011 04:51 AM |
| Sinus Live SL-A3000 | markusb2 | Car Audio | 1 | 28th August 2010 09:01 PM |
| Pitch Adjustment on SL-1500 | schulzr | Analogue Source | 9 | 10th September 2007 09:51 AM |
| Page generated in 0.06846 seconds (83.71% PHP - 16.29% MySQL) with 10 queries |
