Go Back   Home > Forums > General Interest > Car Audio
Old 20th July 2011, 12:25 AM   #1
Default Hifonics BXI 2008D
This amp uses RFP70N06's as the power supply fets with 47 ohm gate resistors.
Wondering if the IRF1010EZ's would be better in this amp or just use the orginals since i have to order all new fets for it ??
Next question is it appears the outputs have been replaced at one point in time. The IRF640N's are in it now .
Would the IRF640's be better or does it even matter?
And the last question is when the guy brought the amp in the transformers and output filter inductors along with the rail caps were still red hot ..
Should i replace the rail caps just to be safe or do u think they might have survived since they were to hot to touch when the amp came in??
Old 20th July 2011, 12:48 AM   #2
Unless someone has used the non-N in place of the N outputs in several amp and can confirm that they are good, reliable subs, use the originals.
I'd also suggest using the original PS FETs as well.
Did the amp fail within a few minutes of him bringing it to you?
Was the heatsink hot?
Old 20th July 2011, 12:56 AM   #3
The amp failed on him and it was still hooked to power when he brought it to me He said it failed 25 mins before he got here And the heatsink was very hot to hot to touch..
Old 20th July 2011, 01:01 AM   #4
The internal components with significant mass may have simply been hot because they were inside the hot enclosure (and possibly in a hot trunk for most of the day).
Unless the caps have signs of failing, they're likely OK. Most caps are good to at least 85C which is VERY hot to the touch.
Hifonics Brutus BXI 2008D mike49504 Car Audio 13 17th February 2012 04:21 AM
Hifonics BXI 2610D mike49504 Car Audio 25 16th June 2011 03:36 AM
Hifonics BXI 1210D mike49504 Car Audio 3 6th May 2011 02:17 AM
HIFONICS bxi 1606d timwebb Car Audio 40 16th September 2010 11:10 PM
Hifonics Bxi 1606d Please Help dmeche Class D 3 25th July 2009 07:15 PM
Page generated in 0.07476 seconds (75.76% PHP - 24.24% MySQL) with 10 queries
