Go Back   Home > Forums > General Interest > Car Audio
Old 21st July 2011, 10:03 PM   #21
m4ick is offline m4ick  United States
There is also +13.1v and +12.7 at the emitter resistors.
Scope - DMM - 460W Computer PSU - Tutorial
Old 21st July 2011, 10:10 PM   #22
And it still does produce -15v for about a second before it disappears. And +15 is steady.
Old 21st July 2011, 11:00 PM   #23
The -15v reg could be defective. If you have a 1 ohm resistor, connect it between the 3rd leg of the regulator and the board. Connect a meter directly across the 1 ohm resistor. If the voltage across the resistor never gets near 1v, the regulator is very likely defective. If the voltage across the 1 ohm resistor is 1v or more, the current draw from the regulator could be shutting it down.
Old 25th July 2011, 07:21 PM   #24
There is about .2V across the 1 ohm resistor.
I've been looking for the LM7915CT and have found it in a TO-220 and TO-220AB.
What's the difference in those packages?
Old 26th July 2011, 03:16 AM   #25
There's essentially no difference.
Old 2nd August 2011, 07:28 PM   #26
With the new regulator installed I have a steady +15 and -15. It is still in protect, one channel has no DC and the other shows -.4v and climbing (toward the negatives) at the emitter resistors.
Old 2nd August 2011, 08:11 PM   #27
Power supply fets are now getting hot quickly as well.
Old 3rd August 2011, 01:38 AM   #28
Which channel has the DC?
Did you replace the power supply FETs?
What work have you done to the channel with DC?
Old 3rd August 2011, 02:30 AM   #29
The channel I did not repair has DC in the negatives and slowly going negative.
Replaced PS fets with 75344G3.
None.
Old 3rd August 2011, 07:21 AM   #30
Left channel? Right channel?
Smoke rolled out of Kicker ZR240 amp chipper Car Audio 13 13th July 2010 09:50 AM
Kicker ZR240 kyle0826 Car Audio 2 19th February 2010 02:26 AM
hello im having a problem 2 i have a kicker zr240 honeyeyedboi_03 Class D 1 4th November 2009 10:58 PM
I need help with blown kicker ZR240! chipper Car Audio 5 13th February 2009 09:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
