Ok i am doing a old school setup with two sanyo PA6100 amp's and i want to mono them but you can't with out some mod's to the pre amp. So here my idea. am i on the right track?
http://www.termpro.com/asp/competito...etitor_ID=2468 |
#2 |
#3 |
Why do you want to bridge it? If I remember correctly, these amps can't drive anything lower than 4 ohms. Bridged, that would be 8 ohms minimum.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
I have ran them at 2ohm stereo with no problems in the past.
#5 |
Were they rated to go to 2 ohms per channel?
#6 |
No but we did it anyways back in the late 80's & early 90's they ran a little hot but did not thermal the amp.
#7 |
They're unlikely to survive and if they use the large output modules, they may not be repairable.
The circuit has a number of problems. Where did you get it from? If you go back and number each component (R1, R2, C1, C2...), I'll try to help with it. What is the purpose for the circuit other than inverting one channel? Where are you getting the ±18v?
#8 | |
http://www.termpro.com/asp/competito...etitor_ID=2468 Last edited by Brain Fried; 20th July 2011 at 06:42 AM. |
#9 |
You could have used one of these also, it has a normal and a 180 out of phase single output thus earning the name sub-woofer crossover/ bridging adapter:
Audio Control 2XS 2-way "Old School" Crossover 90Hz | eBay ![]() Those old Sanyo amps were monsters but they use power amp chips like used in home stereo gear back in the 70's and 80's and they have internal emitter resistors that like to go out of spec when exposed to high current conditions. They are internal to the big chip so they will be unserviceable and the whole chip will require replacement. I think this is what Perry was thinking of concerning the application of running low ohm loads. Had a few of the old Sanyo amps myself... Last edited by 1moreamp; 20th July 2011 at 06:05 PM. Reason: low ohm failures |
#10 | |
| Crazy idea | ak_47_boy | Digital Source | 2 | 7th February 2009 05:38 AM |
| Crazy plate amp idea... | mazeroth | Solid State | 13 | 8th January 2005 06:20 PM |
| Crazy idea ! - thyristor amp | Nysan | Solid State | 6 | 15th April 2004 01:10 PM |
| 4 speakers, 2 channel amp, 1 crazy idea | muskgrave | Car Audio | 31 | 6th April 2004 12:13 PM |
| Page generated in 0.11645 seconds (80.39% PHP - 19.61% MySQL) with 10 queries |
