Go Back   Home > Forums > General Interest > Car Audio
Old 9th July 2011, 11:08 PM   #1
nonprof is offline nonprof  United States
Default KX 1200.1 burnt output inductor
Hello Guys!
Could somebody help me to identify the value of the toroidal inductor at the output stage of this amp? It's burnt and having problem on recoiling, last time I did, found hissing on thjs amp...maybe I did mistake on recoiling.
Thanks in advance!
Old 11th July 2011, 02:35 AM   #2
please help guys...i dont have schematics...thanks!
Old 11th July 2011, 02:52 AM   #3
Send a message via AIM to ComputerJLT
can you count the turns? do u have a pic of the inductor?
Old 11th July 2011, 02:59 AM   #4
Sometimes the cores get cooked and they magnetic parameters change. This makes them unusable. Have you tried contacting kicker for a replacement?
Old 11th July 2011, 04:26 AM   #5
Yeah, I tried to get the inductor value but no answer yet, last time I asked for the replacement of another inductor from separate kicker amp, they said they can't provide the replacement. SO I guess they will not provide this output inductor.
Old 11th July 2011, 04:29 AM   #6
MOER is offline MOER  United States
Default Kicker
60uH use a T130-2 core from Micrometals
Old 11th July 2011, 04:36 AM   #7
Thank you MOER and to everyone who replied!!! more power to DIY'ers...
I will try to recoil and do some calculation to get the number of turns with gauge 17 magnetic wire.
Old 11th July 2011, 05:01 AM   #8
oppsss...its not so easy I guessed. there are a lot of parameters to consider to get the number of turns!
In other way, I still have the burnt coil, I'll measure the length then re-coil the toroid with its length.
but I did this and I failed, it creates a whinning sound. Maybe the high frequency still coming out with these filters...must increase the length of wire then see if the inductance is equal to 60uh, reduce number of turns to get the correct value.
Any advice please?
Old 11th July 2011, 04:23 PM   #9
Although whining could possibly be caused by a defective inductor, the problem could be elsewhere. A defective inductor would tend to make the amp draw excessive current, could make the output transistors run hot or could make the output filter capacitors run hot.
If the inductor failed previously, it could have caused the output filter caps to fail. Have you confirmed that they're within tolerance?
Does the amp otherwise produce clean audio?
Is the whining absolutely constant in frequency or does the frequency change (like tuning an old short wave radio)?
When an output inductor is needed??? Leolabs Solid State 10 2nd October 2011 11:08 AM
Function of Output Inductor caesar148 Solid State 360 19th April 2010 09:01 AM
burnt resistors on speaker output? jol50 Car Audio 7 5th December 2007 04:02 AM
choke for output inductor Tekko Class D 2 25th May 2006 06:04 PM
Source for output air cor output inductor?? sam9 Solid State 7 19th January 2004 02:25 AM
Page generated in 0.08021 seconds (82.91% PHP - 17.09% MySQL) with 10 queries
