Hi all, first post but cant figure this out on my own.
Amp is quite old Soundstream lilwonder 4.480, I was using it as first 2 channels driving speakers and 3;4 channels small pioneer shallow mount sub. Problems started as sub was loosing signal, checked wiring and filter switch and could not find any problems, after cycling filter switch many times sub seemed to work in LPF. But after a while sub burned and amp was in protect mode. So I replaced small power transistors and two D988 transistors, amp is out of protect I was happy, but before putting it back in car decided to test it. First two channels are ok. But the 3. and 4. channels seem not to work in LPF, HPF, FULL modes, it works only in BPF, but is crazy loud, gain to minimum, same settings as channel 1,2 except 1,2 running at FULL. 3. and 4. channels are too loud and distorted.Where to look for problems? I have tested all diodes marked with Z. And small transistors 2sd667 and 2sb647 at channel 3,4 side. What else to test? Thanks a lot for any help. Adding pics of amp: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Do you have a scope or any way to trace the signal through the amp?
Try to get a schematic diagram from Soundstream.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
When amp is running with input audio signal, normally channels 1 and 2 by measuring at output speaker side with multimeter set to AC it is around few volts. But channels 3,4 Set to BPF are around 20V with gain set to minimum. Emailed soundstream and asked for schematics, lets see what they say. Thanks. |
#4 |
Base on the pics i see lots of cold solder joints
#5 |
/\ Would be a good idea to check for cold solder joints, start with the devices clamped to the sink then move on to larger devices on the board then work your way down. That appears to be an asian built soundstream, I didn't realize the lil wonder wasn't built in the US.
Don't worry... you can always turn the gain down! |
#6 |
Bad soldering could be all my job
![]() Resoldered all fets, to get amplifier out of protect mode. Replaced shorted ones. Got an answer from soundstream: ''The schematics are only available to authorized dealers. ''
#7 |
Measure the DC voltage on the output pins of each of the 8 pin op-amps. Does any op-amp have more than 0.1v on the output pins (1 and 7)?
Place the black meter probe on one of the non-bridging speaker terminals. Place the red meter probe on the point where you need to measure the voltage.
#8 | |
#9 |
That's not an op-amp. See attached. Check all similar.
#10 |
| soundstream 480.4 | wazee | Car Audio | 3 | 30th March 2009 09:32 AM |
| All-pass filter problems | f4bok | Chip Amps | 5 | 16th January 2008 07:03 AM |
| eti-480 help | Clum | Solid State | 7 | 1st March 2007 05:26 AM |
| eti 480 build problems | aquasync | Solid State | 15 | 14th February 2005 01:17 PM |
| Eti 480 Pcb | VT Calais | Solid State | 11 | 20th January 2004 09:38 AM |
| Page generated in 0.10959 seconds (80.41% PHP - 19.59% MySQL) with 11 queries |
