Im working on an amp that has tons of corrosion on the board.
The power supply section is where its at the output side of the board looks fine.. Wondering if anyone knows what will take this off the board since acetone doesnt touch it? |
#2 |
I have used brake clean and compressed air alot of times without any issues. You can also use a small wire brush to get the bigger stuff off first.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#3 |
If the components aren't badly damaged/corroded, you can use a fine or soft (brass) wire brush to clean corrosion from the solder side of the board. A pressure washer also does a pretty good job on some amps.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
i used denatured alcohol and some q-tips to clean some minor corrosion off a rockford amp i'm working on. seemed to work quite well
#5 |
I like DeoxIT®, #D5S-6 and and old tooth brush.
#6 |
| Cleaning up | jackinnj | Construction Tips | 5 | 22nd August 2009 12:37 AM |
| copy a circuitboard! | pdul | Everything Else | 19 | 25th June 2009 07:18 PM |
| Cleaning an Amplifier? | mhk62 | Solid State | 6 | 7th December 2004 06:24 PM |
| Old Colony Zen circuitboard warning | Mike L. | Pass Labs | 2 | 12th February 2004 06:11 PM |
| I need program for making circuitboard | partyjups | Solid State | 8 | 3rd July 2001 10:10 PM |
| Page generated in 0.07430 seconds (84.95% PHP - 15.05% MySQL) with 10 queries |
