Go Back   Home > Forums > General Interest > Car Audio
Old 7th July 2011, 05:09 AM   #1
Default Kenwood Kac-819 won't power up!
My kenwood Kac-819 worked perfect for years in my old car. I took it out when I sold my car and now I installed in my new car with my Alpine CDA105 and it won't power up! I took it into Best buy and they bench tested it and it powered for a second but tripped their connection.... I don't understand what could have happened from one car to the next! I took it apart now and it looks clean and everything seems connected and nothing looks blown...
Please help.
Old 7th July 2011, 08:37 AM   #2
It may have shorted output transistors.
If it tripped the protection in their power supply, it should have blown the fuses when you installed it. Did it blow the fuses?
Old 7th July 2011, 04:37 PM   #3
Both fuses are perfectly fine. They both have continuity too! They are both 30amps. Which is what came with the amp when I bought it years ago.
Old 7th July 2011, 05:16 PM   #4
How do I check for shorted output transistors? How much would it cost for me to just replace all 4? Also is it as easy as just unscrewing and then screwing the new ones down tight?
Old 7th July 2011, 08:41 PM   #5
Have you read the entire basic amp repair page yet? If not, (link in sig file below), do so now.
There's no point in replacing parts if you don't know if they're defective.
Old 7th July 2011, 09:14 PM   #6
So if the output transistors are shorted or just one of them is, it would stop the whole amp from powering up?
Also nothing personal, but for basic that guide is WAY in depth and overwhelming...
If it will only cost me like $5 for all 4 output transistors then I would do that in a heartbeat!
How Do I Test them?
Old 7th July 2011, 10:03 PM   #7
The tests are producing conflicting results. I'm assuming that they used a power supply that works well to power up other amps. If that's true, enough current draw to shut it down should be sufficient to blow the fuses.
The outputs for this amp appear to be ~$10 each plus shipping (pacparts and kenwoodparts).
You should not read anything near 0 ohms between the legs of any individual transistor no matter the probe placement on that transistor.
Old 7th July 2011, 11:39 PM   #8
So red probe on left leg and put black probe on middle then read and then black on right probe and read?
Do this for all output transistors?
My readings "should not read anything near 0 ohms between the legs of any individual transistor"?
Old 8th July 2011, 04:09 AM   #9
Well here is what found doing the ohms tests on all 4 of the output transistors. I had the meter set to 200k on the ohm setting.
The readings that I put 1__._ they are the same as no connection; probes not touching anything or themselves!
Old 8th July 2011, 05:05 AM   #10
None appear shorted but that's a bit of a guess since you didn't include the units. I'm assuming that all are k ohms. If you would have filled in the other blanks with the meter set to diode check, it would be more definitive.
KAC-9152D Kenwood - No Power kmil Class D 15 21st December 2010 02:07 PM
Kenwood KAC-941 - Pinout for power plug? HowardSa Car Audio 3 2nd July 2010 04:37 PM
Help Set-up Kenwood KAC-1020 Power Amp ianben2406 Solid State 0 8th March 2010 03:22 AM
Kenwood KAC-8152D no power tritron Car Audio 2 14th May 2008 05:52 AM
Kenwood KAC-X301T and KAC-X201T:Do they share the same board? spooney Car Audio 1 25th October 2007 01:08 AM
Page generated in 0.09659 seconds (76.81% PHP - 23.19% MySQL) with 11 queries
