Go Back   Home > Forums > General Interest > Car Audio
Old 1st July 2011, 08:04 PM   #1
Default Jenson A300 HLX
This amp is using a 2N4401 for the bias transistor..
Is there a good sub to for this part?
Old 1st July 2011, 08:29 PM   #2
Ok I guess the other transistors are also defective in the left channel
Are there good subs for the 2N4401 and the 2N4403??
Old 1st July 2011, 10:06 PM   #3
For a bias transistor, changing the transistor to a different part number could result in a bias that's no longer stable over a wide range of temperatures. The MPSA06 may work but you'd need to run the amp up to thermal to confirm that the bias is not drifting. If it drifts upward at high temperatures, it could cause the outputs to fail when the amp gets hot.
Jenson Amp mike49504 Car Audio 4 21st April 2011 04:49 PM
Help for Cambridge A300 please Justcallmedad Solid State 68 18th April 2011 04:48 AM
jenson alnico on ebay karma Multi-Way 0 18th June 2007 04:00 AM
FS:Jenson 100uf 500vdc new cap RogerWilco Swap Meet 2 13th November 2005 08:05 PM
jenson js-1000 home sub shallenn Swap Meet 0 23rd September 2001 12:18 AM
Page generated in 0.06907 seconds (73.84% PHP - 26.16% MySQL) with 10 queries
