Hi all, I am new to repair but not new to car audio or amplifiers. I have been going through all of Perry's links and reading as much as possible and Perry has already helped me fix my USA-50x and my 24XS crossover (Big thanks Perry!) I have had this amp lying around for a few years with a blown channel. The output on the left channel is -41v and -41.9 amps the right channel is 0 and 0 with no input signal to the amp.
It has 1 TL494c and three LM339D's I got the output of all four, I'm not sure which ones you'll need and I can take pics. Also I got the output of all the fets. I don't want to post everything as I'm sure some of it will not be needed. I was just wondering if someone can push me in the right direction?? Thanks |
#2 |
What do you mean '-41.9 amps'?
Have you checked the output transistors in the left channel to see if any were shorted?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Sorry, I set my dmm to what I though was Amps DC. One them appears to be. It's labeled 36P15. I'm sorry this amp is a little confusing on trying to figure out which is left a right because it has fets on three sides.
#4 |
The output transistors in the left channel will have their center legs connected to the left positive speaker terminal. It's probably the 100 series parts.
#5 |
This is what I use to check for shorts right?
#6 |
Yes.
#7 |
These two show -41v on all three legs
#8 |
FQA28N15 and FQA36P15 they are probably both shorted, better check the the gate drive resistors and the source resistors as well. The source resistors are 0.1 ohm 2 watt. The gate drive resistors are probably 10 ohm. Dont have a schematic sitting in front of me. Remove those 2 transistors and see if the DC goes away at the terminal.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#9 |
OK, I had the schematics. Rockford sent them to me, I just have to find them. Thanks I'll do that!
#10 |
You don't check for shorted transistors with power applied.
| Rockford BD1500 | seankane | Car Audio | 19 | 1st June 2011 01:40 PM |
| help rockford bd15001 | stoke | Car Audio | 10 | 5th May 2011 10:16 PM |
| NOISE on audio system (Rockford 500a2, Sony xec1000, rockford PA2) | stoke | Car Audio | 6 | 1st October 2010 10:21 PM |
| Rockford T5002 | Bobdabuilder | Car Audio | 0 | 7th April 2010 11:48 PM |
| my rockford install | frppower | Car Audio | 6 | 11th September 2005 07:29 PM |
| Page generated in 0.09934 seconds (78.62% PHP - 21.38% MySQL) with 11 queries |
