Go Back   Home > Forums > General Interest > Car Audio
Old 30th June 2011, 09:53 PM   #1
Default pioneer crossover cd-635
This crosover came in with Q9 0pen(b1248) and C49 pop.I replace Q9 with a733 for test.I am not getting no output from this crossover.The input is connected to IC 1 which looks like a lil driver board.It is painted all in black i can't tell what sm parts it has.Am only geting +9v on the opamps(c4570ha).should it have -9v to? if any one has a service manual please send it to me Ranks33@hotmail.com
Old 1st July 2011, 12:04 AM   #2
I don't have the manual but many of the Pioneer crossovers work from a 9v supply and have no negative voltage.
The input modules commonly failed on the older crossovers and equalizers but I don't know if that's common for this model. Do you have signal coming out of the module?
Old 1st July 2011, 12:36 AM   #3
Do you no on what pins i should get signal coming out?
Old 2nd July 2011, 05:28 PM   #4
Index of /temp/pioneercd-635
The files are Flash files. Open them with your browser. Right-click to zoom in.
Old 3rd July 2011, 04:59 PM   #5
i have no signal coming out of the module.What can i do to bybass that module?
Old 3rd July 2011, 05:10 PM   #6
The module is required to prevent ground loops. If you bypass it, you will need to use a ground loop isolator at the input of the crossover to prevent having engine noise. If you use the isolator, connect the shield of the input to the chassis of the crossover and the center conductors of each channel to the output pads for the module (remove module).
Old 3rd July 2011, 05:34 PM   #7
The owener was using this crossover in his home on a 12v 7amp power supply.I came up with a lil idea but am not sure if it is safe?Are there any small circuit i can build that will be smaller than the ground loop isolator ?Here is what i did. 25v 10 uf caps on the output pins of the module.The module is still in there.I am geting audio out and all function seems to be working.
Old 3rd July 2011, 05:35 PM   #8
That from the rca inputs
Old 3rd July 2011, 05:41 PM   #9
Power it from a DC power supply with an isolated ground (most wall-warts) and you shouldn't need the GLI.
Old 3rd July 2011, 05:46 PM   #10
Ok thanks
Pioneer HPM series crossover upgrade? Racket Scientist Multi-Way 8 30th November 2010 03:25 AM
yamaha cdc 635 SS64 Everything Else 2 14th June 2010 11:22 PM
FS tubes and EICO 635 for repair woody Swap Meet 2 20th May 2009 04:15 PM
what cd pioneer, marantz, meridian? Williams Audio Digital Source 3 3rd July 2005 04:44 PM
Pioneer Cd Mod's jleaman Solid State 2 2nd May 2004 06:42 AM
Page generated in 0.10634 seconds (77.59% PHP - 22.41% MySQL) with 11 queries
