Go Back   Home > Forums > General Interest > Car Audio
Old 29th June 2011, 06:17 PM   #1
Default MTX TC 3002
This amp is in protection mode All the power light does is blink every now and then..
The outputs are out of the amp right now because i found a bad emitter resistor and wanted to rule the outputs out as the fault..
Heres what i get on the 494
Pin 1ulsing
Pin 2:4.61
Pin 3:0.06
Pin 4:4.94
Pin 5:1.49
Pin 6:3.34
Pin 7:0
Pin 8:13.26
Pin 9:0
Pin 10:0
Pin 11:13.26
Pin 12:13.26
Pin 13:4.95
Pin 14:4.95
Pin 15:4.95
Pin 16:0
Heres what i have on the 339
Pin 1:0.07
Pin 2:4.91
Pin 3:13.26
Pin 4:0.06
Pin 5:3.09
Pin 6:4.94
Pin 7:3.09
Pin 8:3.94
Pin 9:4.94
Pin 10:4.95
Pin 11:8.27
Pin 12:0
Pin 13:0.07
Pin 14: 0.07
Any Ideas?
Old 30th June 2011, 08:27 AM   #2
I have no information on this amp but going by notes on other MTX amps, I'd guess that the fault is triggering the 339 on pin 6. I think this is likely the thermal protection input from the transistors that are driven by the thermistors. This is nothing more than an educated guess. Photos may help if you can't trace the fault out from the information above.
Old 30th June 2011, 12:54 PM   #3
So back track from Pin 6n the 339 ??
Old 30th June 2011, 03:04 PM   #4
I replaced the transistors that go to the thermistor and still the same amps goes into protection
Old 30th June 2011, 11:49 PM   #5
Is there anything else connected to the trace that goes to pin 6?
Linear Power 3002? Torbar Car Audio 6 13th November 2008 11:43 AM
Problem with Linear Power 3002 kappa546 Car Audio 3 1st October 2008 08:09 PM
TC Sounds (aka Audiopulse) LMT TC-9 (predecessor to LMS) DavidJanszen Swap Meet 1 5th June 2008 05:32 PM
linear power 3002 help amc32 Car Audio 0 14th March 2008 07:30 PM
advent 3002 woofer johngalt47 Multi-Way 1 13th September 2006 12:16 AM
Page generated in 0.07061 seconds (74.78% PHP - 25.22% MySQL) with 10 queries
