Hi all, is anyone familiar with this amp? last of the decent Sony stuff, seams quite well built inside! anyway, the issue is it's stuck in protection and pulling 8 amps, all psu fets and outputs check out OK, something tells me it's a shorted transformer, I poked around a bit there and amp draw is around 1 amp now but amp still in protection.. will measure V on pwm if that helps..
Mark. |
#2 |
kinda fixed this! as mentioned above, the amp is now only pulling 1amp and works fine, but I wriggle the transformer it goes back up to 8amps! i can see where it's shorting and it's the thinner wires. what can I use to isolate the wires? lacquer of some description?
#3 |
It depends on the point where it's shorted. If you can slide an adhesive coated insulator (can be as simple as a piece of paper coated with adhesive), that will stop the windings from shorting.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Sony XM-2252HX | seankane | Car Audio | 13 | 30th April 2011 02:19 PM |
| Sony XM-GTA2022 | mike49504 | Car Audio | 4 | 12th March 2011 04:05 AM |
| Sony XM-1004gx | mike49504 | Car Audio | 33 | 26th March 2010 08:10 PM |
| Sony XM-4520 | croccodillo | Car Audio | 0 | 14th December 2005 09:19 AM |
| Sony XM Radio | Sawzall | Digital Source | 2 | 3rd January 2002 04:46 PM |
| Page generated in 0.06052 seconds (70.77% PHP - 29.23% MySQL) with 10 queries |
