Go Back   Home > Forums > General Interest > Car Audio
Old 24th June 2011, 11:03 AM   #1
gruni is offline gruni  Germany
Default Amplifier design for 2 Ohms without SMPS
Hi everybody,
i'm planning to build an amplifier that can push up to 100 Watts (which would mean 14.1 Volts of output swing) or as much as the power supply voltage allows into a 2 Ohm load using a bridge configuration, running directly from low voltage supply without a SMPS. So it would have to withstand about 7 Amps. Are there any finished designs known to perform good? Otherwise, where should I start?
Old 24th June 2011, 04:35 PM   #2
There are likely several chip-amps that can do this very easily/simply. Try posting this on the chip amp forum to see if anyone has any suggestions.
15 ohms (12 on ohmmeter) with 24 ohms resistor in parallel to bring to 8 ohms McIntosh Man Multi-Way 29 11th June 2010 05:36 PM
power amplifier 400w @ 4 ohms divojara Solid State 8 22nd June 2007 06:54 AM
2 ohms design diy guy Solid State 7 25th July 2006 10:32 AM
2 Ohms stable Transistor Amplifier... SkinnyBoy Solid State 14 1st April 2003 01:27 PM
60w in 8 ohms ESP amplifier... Lisandro_P Solid State 15 19th April 2001 05:20 PM
Page generated in 0.06404 seconds (68.29% PHP - 31.71% MySQL) with 10 queries
