Go Back   Home > Forums > General Interest > Car Audio
Old 23rd June 2011, 10:59 PM   #1
Default New On This Forum, Sub Woofer Question
hello My Name's Rob
i have a 2010 Dodge Charger
which I will Be Installing the following things
MB Quarts Qs216 6.5 front and back
JL Audio HD600.4
JL Audio HD750.1
And Here Is where My Problem Lies (SUB WOOFER)
Ive Been told by Many to Go With The Orion® XTRPRO124 12-Inch 1000 Watt Dual 4 Ohm Subwoofer:
12" XTR PRO Dual 4 ohm Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Polypropylene dust cap and paper cone is moisture and UV resistant
Nitrile-butadiene rubber surround enhances the linear excursion
Symmetrical tuned long-throw surround
Dual interlaced conex spider
Custom cast aluminum frame
Custom trim ring
Tinsel leads stitched and looped across spider
Tri-cooling system
Copper wound voice coil on aluminum former
Venting in voice coil former is part of the enhanced voice coil cooling system
Advanced forced convection cooling system
Sensitivity: 82 dB
Two large 48 oz. double stacked ceramic magnets (96 oz. total)
But Others tell me to go with JL Audio 12W3v3-4
2" Single 4 Ohm W3v3 Series Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Recommended Power Range: 100-500 watts
Impedance: Single 4 ohms
Mineral-filled polypropylene upper cone with a metallic JL Audio medallion logo gives the W3's a whole new, classy and sophisticated look
NBR (Nitrile Butadiene Rubber) surround
DMA-optimized, long linear excursion capability to virtually eliminate distortion and increase sound output
Perform outstanding in compact sealed or ported enclosures
DMA (Dynamic Motor Analysis) modeling to deliver unsurpassed dynamic stability and low-distortion operation within intended power range
Sensitivity: 87 dB
Free Air Resonance (Fs): 28.28 Hz
Electrical "Q" (Qes): 0.553
Mechanical "Q" (Qms): 6.936
Total Speaker "Q" (Qts): 0.512
Equivalent Compliance (Vas): 2.729 cu. ft (not recommended box size)
Xmax Linear Excursion: 0.510 in. / 13.0 mm
Driver Displacement: 0.071 cu. ft.
Net weight: 14.50 lbs.
Ive Been Told THAT DUAL WILL ALWAYS BE BETTER THAN SINGLE COIL BUT THE JL AUDIO IS STILL BETTER EVEN THO IT HAS A SINGLE COIL
CAN SOMEONE PLEASE HELP!!!!!
Old 24th June 2011, 12:32 AM   #2
In my 15+ years of tinkering with my own mobile setups and many friends/families cars, I've never heard a JL Audio sub that wasn't impressive, provided it was in a well built correct enclosure.
AFAIK, you've been misinformed as to the dual coil thing. What a dual coil sub does is provide more flexibility in wiring, it does nothing to improve sound quality.
Here's the JL sub you mentioned cheap
Car Audio wholesale distributor Alpine Pioneer HID Lights Clarion Hifonics Kenwood Boss - Ikesound.com - JL Audio 12W3v3-4
FYI, you'll likely get more feedback in the Car Audio section of the forum. Welcome !
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas
Old 24th June 2011, 12:37 AM   #3
Speakerholic
Cal Weldon's Avatar
I'm moving this to car audio for obvious reasons. Good luck with the answers.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th June 2011, 02:07 AM   #4
DVC only gives you more flexibility on loads. You can wire them different and get different loads (what ever fits your amplifier better).
I for one dont think DVC are any better than SVC, except for more different loads. Another good thing about DVC is if one voice coil goes out you still have one left, just dont expect to get the full rated power. The power is actually cut NOT in half, but 2/3 of the power rating is lost.
Keep in mind the bigger the voice coil the more power handling it has. I just can't see how a 2" voice coil and a 96oz ceramic magnet can produce 1000watts. My favorite sub (the stroker) has a HUGE magnet @ 25lbs, yes its measured in lbs not oz (which is about 400oz) and is rated at 1000watts. I used 250watts before and that does the trick.
Old 25th June 2011, 12:24 AM   #5
thanks so much sry but now im confused the link you sent me says its 300rms other sites say 500
Forum novice wants some sub-woofer help. funkofilia Subwoofers 5 29th December 2011 05:44 AM
Forum 'Category' appears at the top of the forum list dfidler Forum Problems 0 14th August 2010 07:55 PM
Forum donation in honour of a forum member tinitus Everything Else 0 25th October 2009 01:45 PM
excelent - new forum - time for another stupid question... fezz Chip Amps 24 8th May 2003 04:22 PM
French people on the forum ? Des Français sur le forum ? frankie Introductions 19 30th December 2002 08:40 PM
Page generated in 0.09501 seconds (82.52% PHP - 17.48% MySQL) with 10 queries
