Go Back   Home > Forums > General Interest > Car Audio
Old 20th June 2011, 04:27 AM   #1
Default 3 amps, same issue
With power and ground hooked up as soon as i hook up the remote wire my cd player starts flashing, cutting out, etc. I have the cd player hooked up to my astron power supply. Ive never had this problem before and i test amps all the time, but ive tested 3 in the last month that do this. They drawing too much current or? Thanks
Old 20th June 2011, 05:54 AM   #2
Does the astron have an amp meter?
Old 20th June 2011, 06:05 AM   #3
Yeah, i noticed on the last one(eclipse 32440) that it jumped back and forth. Cant recall if it did it on the RF Punch 150 25 to life though. I'll power it up again. The third amp is being used as a parts amp so i am unable to do much with that anymore. Thanks
Old 20th June 2011, 06:07 AM   #4
Oh, by the way, that power Acoustik BAMF 5500/1d i talked to you about had a bad connection on one of the power rails, just needed some solder and it was good to go. Maybe i should leave a message in my thread about it, might help others. Thanks
Old 20th June 2011, 06:08 AM   #5
If it's pegging the amp meter, the current draw is greater than the supply can deliver. Generally, when a standard head unit is used as a signal source, a second, smaller power supply is used to power the head unit. This prevents the head unit from shutting down when too much current is drawn from the main supply.
Old 20th June 2011, 06:23 AM   #6
Makes sense. So its possible there isnt anything wrong with these amps? And do you have any other recommendations on a signal source? Thanks
Old 20th June 2011, 06:30 AM   #7
What's the current rating of the power supply?
A standard head unit is OK, especially when you have a separate power supply for it.
Old 20th June 2011, 06:38 AM   #8
Its a rs-50m. 13.8 VDC 37 Amps continuous 50 Amps ICS
Old 20th June 2011, 06:40 AM   #9
Assuming that the power supply is in good working order, I'd suspect that those amps had shorted output transistors (if the excessive current draw was only after remote voltage was applied).
Old 20th June 2011, 06:40 AM   #10
The head unit has a 15 amp fuse
Samson Servo 550 issues, multiple amps, same issue. cwahls Solid State 16 Yesterday 04:19 PM
Burr Brown op amps,in amps,power op amps for sale magneticnorth Vendor's Bazaar 1 23rd September 2010 10:50 PM
which NAD older generation amps & integrated amps are bipolar or mosfet? audionaut99 Solid State 3 21st May 2010 10:09 AM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
Page generated in 0.09331 seconds (77.28% PHP - 22.72% MySQL) with 10 queries
