Lanzar Optidrive 4000D problem
Old 19th June 2011, 09:36 PM   #1
Custom Chris is offline Custom Chris  United Kingdom
Default Lanzar Optidrive 4000D problem
I have an Opti4000D (same board as the SS XXX6500 I hear)
The problem is, that some frequency's sounded a bit like they had a 'stutter' to them. It only seemed to happen from about vol 18/26.
I adjusted the gain to zero and kept the headunit low then adjusted the volume to see if it was the amp or headunit. I then tried this with the gain. I have now found it is the amplifier at fault.
When I turned the gain up to a certain point and the bass went from sounding like a clean signal to a noise which I can only describe being like someone had dubbed over my CD with another bass-heavy track. It was still making bass, just not what I was playing...
It does not do this with the RCA's unplugged.
The amplifier switches on and works every time.
I have since checked ALL fets and output transistors and everything gives correct readings.
Has anybody seen this problem before?
Old 19th June 2011, 10:54 PM   #2
Perry Babin is offline Perry Babin  United States
Have you confirmed that the shield ground on your head unit is intact?
Old 19th June 2011, 11:28 PM   #3
Yes. I have actually put another amp in the car temporarily while I diagnose this...
It works fine.
Old 20th June 2011, 12:08 AM   #4
Was the second amp identical?
Old 20th June 2011, 12:12 AM   #5
No, it was a pair of Kenwood 9152D's strapped.
Old 20th June 2011, 12:29 AM   #6
The two amps use a different input circuit and may not react the same to a bad shield ground. Check the shield ground and confirm that it's essentially 0 ohms for the head unit.
This seems more like a preamp level problem than anything else.
Old 20th June 2011, 01:07 AM   #7
OK thanks Perry. Will check and report back.
Old 20th June 2011, 08:42 PM   #8
Hi Perry, did a few checks with the DMM today.
The RCA shields came back with 0.02Ohms so I assumed that they were OK. I checked and swapped the RCA's for some other known good ones.
I'm not sure if this means anything, I am hoping you can shed some light on it.
I checked the resistance between the RCA outer jacket (whilst plugged in to the amp) and ground. I got about 18-19Ohms. Does this sound about right?
I also noticed that touching a ground source the the shields on the amp (either input or output) gave a slight 'thud' at the sub...
You guessed it, I did a few gut shots of inside the amp which I'm about to upload. There are a few items that appear to have either been added on or fixed at some point... I'll get these uploaded now. Thanks
Old 20th June 2011, 08:45 PM   #9
PS: Maybe some more useless information but, the resistance between the RCA plugs at the amp end (but not connected) and ground read -16.7Ohms
Again, I'm not sure if this is relevant or not?
Old 20th June 2011, 10:39 PM   #10
Lanzar Optidrive 4000D problemHide this!Advertise here!
Need Help With Lanzar OptiDrive KansasKowboy Car Audio 2 1st April 2010 02:41 PM
lanzar optidrive 1400d Hi Speed Car Audio 1 26th March 2010 03:38 PM
lanzar optidrive 2500 abortion amc32 Car Audio 4 20th April 2008 08:41 PM
Lanzar Optidrive 6200 LORNECALIFORNIA Car Audio 2 18th January 2008 02:03 AM
Schematics Lanzar Optidrive 100 Tms gcu Swap Meet 0 26th November 2005 04:20 PM
Copyright ©1999-2017 diyAudio
