Go Back   Home > Forums > General Interest > Car Audio
Old 19th June 2011, 03:31 PM   #1
Default Soundstream xxx-6500
I am working on this amp, in diode check the irf p360's are measuring .026 in diode check on the outer legs either way you place the probes on the right side of the amp on the left i am getting o/l either way same thing if you pull the driver board n channel is fine, I have pulled all the fets, and the swiches (RA A12s) fets are fine out of the board swiches are to any ideas?
Old 19th June 2011, 03:35 PM   #2
What is the amp doing?
Does it power up but no output?
Does it draw excessive current?
Old 19th June 2011, 06:41 PM   #3
Please repost but this time, use the exact circuit board designations (the white numbers on the board next to the component) for every component that you refer to in the post. Check to be sure they're correctly typed. If you're referring to multiple components as a group, list every component in the group.
Soundstream XXX 4000 D mike49504 Car Audio 2 29th November 2010 01:58 AM
soundstream xxx 6500D mike49504 Car Audio 3 26th November 2010 06:52 AM
Soundstream XXX 4000D mike49504 Car Audio 1 31st August 2010 10:06 PM
soundstream xxx 10000 mike49504 Car Audio 1 7th April 2009 04:53 PM
Schematic Soundstrean XXX 6500 JoergST Car Audio 0 1st August 2007 06:32 PM
Page generated in 0.06740 seconds (73.44% PHP - 26.56% MySQL) with 10 queries
