Go Back   Home > Forums > General Interest > Car Audio
Old 17th June 2011, 02:15 PM   #1
Default Boosting line out and adding low-pass
Hi all, I've been out of electronics for a long long time, but my daughter and I just built a crystal set together and thats kind of got me interested again. However, I digress...
I've got a cheap but ok-sounding head unit in my car which has a single line out (part of the rear speaker circuit, not a dedicated sub out), and a cheap 4 x 35W bridgeable Sony amp, and a couple of 10" Infinity subs I got cheap (Getting the idea? I am cheap - well, actually I have a wife and daughter, so I'm cheap because I have to be, not because I want to be ). The car has 4 x 6.5" speakers, which I am running from the 4 speaker outs on the head unit, and the line out is run to the amp. I have both channels bridged in the amp (the booklet for the amp only documents one as bridgeable... but experimentation has led me to discover they both are - and nothing has blown up yet ), and each bridged channel runs one sub.
This is fine, and it makes the right noise when wound up - but at low levels I can't get enough bass from the subs to really even know they are there - even with every bass control wound fully up, and the input level on max on the amp. So, I'd like to put a pre-amp in-line with the amp to boost the signal so the subs should be more audible. I'm assuming that doubling the level would suffice as a max gain? And while I am doing this, I'd like to add some sort of low-pass filter to remove unwanted high frequencies (the amp has a low pass filter for one channel, but not the other).
So, I went looking and found lots of pre-amp circuits... but they all need +/-15VDC or so... which is a problem in a car without a DC-DC converter. I've had a look around on here and discovered the LM4562 which I could possibly use with a simple voltage divider and run it on +/-6ish volts.
I would love some input on design and problems I will face - will this IC work? Will the voltage fluctuation from the car supply be a problem? Can I fix that with - say - 5.1V zeners and run the opamp on +/-5.1V? Could I include an adjustable cutoff for the low-pass? And does anyone have a suitable circuit I could use as a basis for the design (or one already made?). As I said, I am a long time out of electronics as a hobby, but keen to get back in... and although the brain is a little rusty, its keen to try
Cheers in advance for any help
Steve
Earthquake City (Christchurch, New Zealand)
Old 17th June 2011, 02:27 PM   #2
single supply subwoofer preamp with low pass, works on a single supply..
here you go ...
Car Subwoofer Driver - RED - Page142
Old 17th June 2011, 04:52 PM   #3
That circuit doesn't have any way to isolate the audio ground from the chassis ground which is likely to cause engine noise unless it's used with a ground loop isolator.
±15 can probably be taken from within the sub amp if it has a switching power supply.
What model is the sony amp?
Old 17th June 2011, 07:51 PM   #4
Yes it doesn't have isolation, will cause whine noise, you need to isolate both via an 1:1 transformer.. I've used a 1.1Kohm transformer to isolate..works flawlessly..
Old 18th June 2011, 01:32 AM   #5
here you go ...
Many thanks for that circuit... I'll have a crack at it.
I've got a 600R:600R isolating tx here somewhere - I'll try using that.
I totally didn't even think about that... I could probably even build the booster into the amp itself (although I was going to put it in the dash so I could adjust it at will.
Thanks for the ideas guys, I'll give it a go...
Steve
Passive low-pass passive for line input - 2nd part andreaemme Analog Line Level 0 9th June 2011 02:04 PM
Passive low-pass passive for line input andreaemme Analog Line Level 5 8th June 2011 04:14 PM
Low Pass Filter in line with a Piezo Transducer ShaunL Parts 0 15th June 2007 04:52 AM
Line-Level Low-Pass Filter Design JustinAtGT Chip Amps 10 31st May 2006 08:48 AM
Passive line level low and high pass filter help Matttcattt Multi-Way 53 24th February 2004 04:16 PM
Page generated in 0.09875 seconds (82.60% PHP - 17.40% MySQL) with 10 queries
