Go Back   Home > Forums > General Interest > Car Audio
Old 16th June 2011, 10:12 PM   #1
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Default MTX RTP251D wont power up
Ive got another one of these little amps which will not power up. I removed both power supply fets from the board because my meter is measuring 32ohms across Legs 1&2, only to find the 32ohms is something on the board and the fets are likely OK. There is no voltage on the gates of the fets.
TL494:
Pin 1: 0.001
Pin 2: 4.74
Pin 3: 0.000
Pin 4: 4.98
Pin 5: 1.512
Pin 6: 3.368
Pin 7: 0
Pin 8: 13.24
Pin 9: 0
Pin 10: 0
Pin 11: 13.24
Pin 12: 13.24
Pin 13: 4.97
Pin 14: 4.97
Pin 15: 4.97
Pin 16: 0.000
Old 16th June 2011, 10:28 PM   #2
ultra is offline ultra  Greece
ultra's Avatar
i happened to be online when i read your post.
Without wanting to take the chair of Perry Babin,
you could start looking why pin 4 has almost 5 volts.
Normally, voltage at that pin should be close to 0.
Old 16th June 2011, 10:34 PM   #3
If it has an LM339, post the voltage on all of its pins.
Old 17th June 2011, 02:48 AM   #4
Dr Zeus's Avatar
LM339
Pin 1: 0.072
Pin 2: 4.96
Pin 3: 13.22
Pin 4: 0.072
Pin 5: 3.117
Pin 6: 0.803
Pin 7: 3.117
Pin 8: 0
Pin 9: 4.99
Pin 10: 4.99
Pin 11: 0
Pin 12: 0
Pin 13: 0.073
Pin 14: 0.073
Old 17th June 2011, 05:29 AM   #5
It doesn't appear that you have remote voltage applied. Follow the remote from the terminal to see where it's being lost.
Old 17th June 2011, 11:30 AM   #6
Dr Zeus's Avatar
Found a broken trace under a rail cap. Now I've got to figure out why it happened. This trace is directly connected to REM.
Old 17th June 2011, 11:38 AM   #7
Dr Zeus's Avatar
Now I see what happened. Looks like the bottom/under part of the rail cap may have actually touched and shorted out this trace. Interesting.
Old 17th June 2011, 11:44 AM   #8
Dr Zeus's Avatar
I just realized that I can not successfully repair or build-up this trace under the cap for risk of it shorting again. Instead, I removed all the lifted trace material and added a jumped underneith the PCB as pictured. This should do the trick.
Old 17th June 2011, 11:57 AM   #9
Dr Zeus's Avatar
The amp now seems to want and try to power up, but the power supply fets are getting hot with power attached and the amp is draining my power supply.
In post one I had found 31ohms across legs 1 to 3 of both fets. I think there is some problem here maybe like a shorted driver or something causing the amp to bridge the gate resistors which are 31ohms.
Old 17th June 2011, 06:17 PM   #10
Dr Zeus's Avatar
There is no signal coming off pins 9 & 10 of the TL494. The signal from pins 9&10 run through a tiny transformer and then through a pair of ~60ohm resistors in paralel (~30ohms) to the fet gates.
TL494
Pin 1: 0.099
Pin 2: 4.74
Pin 3: 0.067
Pin 4: 0.833
Pin 5: 1.516
Pin 6: 3.337
Pin 7: 0
Pin 8: 12.90
Pin 9: 0
Pin 10: 0
Pin 11: 12.97
Pin 12: 13.17
Pin 13: 4.97
Pin 14: 4.97
Pin 15: 4.97
Pin 16: 0
LM339
Pin 1: 4.74
Pin 2: 0.001
Pin 3: 13.16
Pin 4: 4.76
Pin 5: 3.413
Pin 6: 0.987
Pin 7: 3.411
Pin 8: 4.093
Pin 9: 4.99
Pin 10: 4.99
Pin 11: 8.62
Pin 12: 0
Pin 13: 4.78
Pin 14: 4.78
Crossfire CFA202 wont power up Dr Zeus Car Audio 8 17th November 2010 11:47 PM
Zapco system 151-A wont power up robertleo Car Audio 5 22nd August 2010 02:23 AM
Amp wont power on, just keeps blinking, help! Mach1Chris Car Audio 7 4th May 2005 02:49 PM
Page generated in 0.10101 seconds (79.96% PHP - 20.04% MySQL) with 10 queries
