hey guys!Ive had a problems before, with my mtx 1501d(burn powersupply).Ive replace the 8 power transistors(Fet 436-441) and the to resistors(r436 r435),that was bad!Now the amp turns on,an it plays,but the power supply is making a high pitch noise.Also Led 238&399 are on also.The only reason i think it plays is because the owner before me mod this amplifier!Do anybody have any ideas as to why this is happening !!Also,before it stop working,the power supply whould make noise when i first turn it on,then it would go away.I also notice the yellow caps looks funny.( in the power supply area,in front of the FET transistors)one of them looks like it was leaking before.thanks
#2 |
The power supplies in these amps can be very noisy.
Does the heatsink under the power supply FETs get hot quickly when you drive the amp hard? Most of the yellow caps are film caps and therefore can't leak. If the case isn't melted on the film caps, the substance you see on the board is likely from something else. I'm assuming that you're referring to the film caps because I've never seen a 1501 with yellow electrolytic caps.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 | |
#4 |
Played it for like 10 mins.It didn't get hot At all,just that the power supply was noisy!
#5 |
LED 463 should be lit when remote voltage is applied.
LED238 should be lit after the initial mute delay. LED399 (between the large caps?) will be lit when the large capacitors are charged.
#6 |
Thanks For the Info
#7 |
One more question.I cant remember which way the button inside the amp should be??In or out?The button for 18v input.
#8 |
I know of no '18v' button. Is this mentioned in the owner's manual? If so, email me a copy or the text associated with it.
#9 |
This may be modded, I remember talk of this amp when it came out of people modding them. I just googled and found a bunch of pages of people doing this for this particular amp.
#10 |
I talk to a mtx tech today.That button is a safety protection bypass button.Use in car audio competition,so you may double stack amps,run lower ohms output,and run a higher input voltage!In normal use,this button should be in the out position
| MTX Thunder 1501D | spooney | Car Audio | 49 | 16th July 2010 04:55 AM |
| Mtx 1501d | catfishermike | Car Audio | 10 | 19th May 2010 05:56 PM |
| IC3120 (split from mtx 1501d ) | calebjoshito | Car Audio | 4 | 30th June 2008 02:44 AM |
| mtx 1501d | ONEGGT | Car Audio | 0 | 18th October 2007 08:07 AM |
